Thread: Removing front valve color?
Results 1 to 19 of 19
  1. #1 Re: Removing front valve color?
    id still be doing compression test.
    if a valve spring broke there would most likely be more than just a clicking noise. you'd hear the rocker clapping.
    the flashing cel most of the time is one hell of a misfire or a clogged cat will also make it flash.
  2. #2 Re: Removing front valve color?
    Donating Users LS2 BLAZER's Avatar
    Lorain, OH
    i second that... clogged cat made mine go nuts... flashing CEL like crazy... did the free misfire test to see if wires were arching, etc... (soapy water spray on the wires), wasnt the issue, took her to the dealer, and instantly knew it was the cat.
    2001 Grand Prix GT - stock (for now )
    2007 Trailblazer SS - back under the knife , motor #4 on the way
  3. #3 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    Took a compression test cyl #4 shows 25lb Tested it 5 times, 1 time out of 5 it went to 100lb, could this be a collapsed lifter? and still not be noisey, is there anything I can try to free the lifter?
  1. Removing the Boost Bypass Valve?
    By lilrocket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2012, 02:51 PM
  2. removing valve covers?
    By bps02gtp in forum General Tech Discussion
    Last Post: 07-08-2011, 10:29 PM
  3. Removing Valve Covers
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 11:04 PM
  4. Removing front panel from console
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2010, 10:09 PM
  5. Help Removing EGR Valve Pipe
    By ShevanelTakeTwo in forum General Tech Discussion
    Last Post: 02-06-2010, 04:49 PM
