Thread: Removing front valve color?
Results 1 to 19 of 19
  1. #1 Removing front valve color?
    Aug 2012
    Richland oregon
    Do I have to remove the motor mount from the block in order to have clearance to remove the front valve cover? this looks like a big job, I've removed the ICM and coils packs. Help
  2. #2 Re: Removing front valve color?
    You have to remove to coil bracket and it should pop right off.
  3. #3 Re: Removing front valve color?
    Portland Oregon
    3 bolts and it's off. Not a terribly big job. You don't need to take the coils or ICM off though.
  4. #4 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    The three bolts holding the motor mounts? does this also include the tensioner?
  5. #5 Re: Removing front valve color?
    the tentioner comes off with the bracket, make sure you put it back on right, and dont forget the ground wire when you put it back on.
    not a hard job.
  6. #6 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    thanks
  7. #7 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    I'm removing to check my rocker assembly, do you see many failures, it's not noisey however It runs rough and smoother with #1 wire disconnected, have changed spark plug, wires, coil, ICM.
  8. #8 Re: Removing front valve color?
    id do a compression test first then.
    when this first happened was the plug damaged, like pieces missing from it or smashed looking?
  9. #9 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    No everything looked normal, while on a long trip started with a clicking noise put a little seafowm in the crank case quit making noise after a couple more hours of driving, have check engine flashing and running rough have checked all injectors, replaced wires and plugs 1/4 coil and Icm can't really hear any tapping noise.
  10. #10 Re: Removing front valve color?
    What brand plugs and gap?
  11. #11 Re: Removing front valve color?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    If check engine light is flashing, you need to stop immediately!!!! Drive at your own risk of severe damage to the motor.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  12. #12 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    ac delco, 58 gap
  13. #13 Re: Removing front valve color?
    id still be doing compression test.
    if a valve spring broke there would most likely be more than just a clicking noise. you'd hear the rocker clapping.
    the flashing cel most of the time is one hell of a misfire or a clogged cat will also make it flash.
  14. #14 Re: Removing front valve color?
    Donating Users LS2 BLAZER's Avatar
    Lorain, OH
    i second that... clogged cat made mine go nuts... flashing CEL like crazy... did the free misfire test to see if wires were arching, etc... (soapy water spray on the wires), wasnt the issue, took her to the dealer, and instantly knew it was the cat.
    2001 Grand Prix GT - stock (for now )
    2007 Trailblazer SS - back under the knife , motor #4 on the way
  15. #15 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    Took a compression test cyl #4 shows 25lb Tested it 5 times, 1 time out of 5 it went to 100lb, could this be a collapsed lifter? and still not be noisey, is there anything I can try to free the lifter?
  16. #16 Re: Removing front valve color?
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    could be a sticky lifter, no? you said the noise stopped when you seafoamed it?
  17. #17 Re: Removing front valve color?
    pretty sure you need to take all the plugs out and then test the cylinders one by one, so to be able to compare your numbers.
    at least thats how ive done it in the past.
  18. #18 Re: Removing front valve color?
    Aug 2012
    Richland oregon
    Replaced the #4 intake push rod, runs great, I added rislone to the oil, I think I'll start it every few hours allowing the rislone to do it's job just in case my lifter caused the propblem. Any other suggestions appreciated.
  19. #19 Re: Removing front valve color?
    That's great that you have it fixed. Hope long term it's good for you.
  1. Removing the Boost Bypass Valve?
    By lilrocket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2012, 02:51 PM
  2. removing valve covers?
    By bps02gtp in forum General Tech Discussion
    Last Post: 07-08-2011, 10:29 PM
  3. Removing Valve Covers
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 11:04 PM
  4. Removing front panel from console
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2010, 10:09 PM
  5. Help Removing EGR Valve Pipe
    By ShevanelTakeTwo in forum General Tech Discussion
    Last Post: 02-06-2010, 04:49 PM
