Thread: Couple of specific speed daddy header quesions
Results 1 to 8 of 8
  1. #1 Couple of specific speed daddy header quesions
    Cambridge, Ontario Canada
    Done lots of reading but neee some more specific answers. My current exhaust is welded front to back.
    When applying rtv, how do you apply it? Pics would be very helpful as i have never used that stuff on an exhaust before
    Use stock exhaust gaskets, just clean em?
    Use stock header bolts? Any install into coolant areas?
    If i was to use the sd flex for now and it failed later, can a new one be nicely welded on car or do i have to remove rear manifold?
    2005 E55 - stock
  2. #2 Re: Couple of specific speed daddy header quesions
    Portland Oregon
    New flex could be welded on the car but it would be much easier removing the rear header. When you apply rtv just take your finger and smear it on the slip joints for the crossover on the end of the pipe. You can use your stock bolts as well, no need to buy header bolts. I would buy the better clamps for the crossover though
  3. #3 Re: Couple of specific speed daddy header quesions
    Got the better clamps but they are not stepped clamps does that matter?
    2005 E55 - stock
  4. #4 Re: Couple of specific speed daddy header quesions
    GT Level Member al2000gtp's Avatar
    Buda,IL
    i used clamps without the step and no rtv and still had a leak on my crossover with my sd's. Then i got some stepped band clamps and some rtv and no more leaks now
    2000 GTP - HAI, SD Headers, 3" catback, cat delete, thrush turbo muffs, self ported sc, and transgo shift kit.
  5. #5 Re: Couple of specific speed daddy header quesions
    I could not find stepped clamps locally.
    2005 E55 - stock
  6. #6 Re: Couple of specific speed daddy header quesions
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    new gaskets, rule of thumb for most things is usually getting a new gasket when u disturb one because it wont seal well again. especially the exhaust ones. you might even have to grind them off. i had to do that when i put on my catback.
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  7. #7 Re: Couple of specific speed daddy header quesions
    For the O2 sensor I was thinking replace front one then use the old ones wires & to splice & extend harness. I am assuming the rear one will be fine?
    1. will that be long enough?
    2. I need the "upstream" O2?
    Oh yeah, I didn't need to do any kind of modification to the firewall whatsoever...
    2005 E55 - stock
  8. #8 Re: Couple of specific speed daddy header quesions
    Sounds like a case of ... Didn't read install thread.
    RTV on exhaust.. not needed if you install properly.
    Gaskets.. yup wipe
    Yes on bolts, no they are in non water jacket areas.
  1. Speed daddy header egr issue
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2011, 05:47 PM
  2. Speed Daddy Header install writeup
    By vailskier3 in forum General Tech Discussion
    Last Post: 10-26-2011, 09:28 AM
  3. speed daddy s/c or not
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2011, 07:47 PM
  4. speed daddy's
    By Feminist turnip in forum 04+ Specifics
    Last Post: 02-02-2011, 08:53 AM
