Thread: I'm a Noob and need injector help please!!
Results 1 to 7 of 7
  1. #1 I'm a Noob and need injector help please!!
    Aug 2012
    Cushing, OK
    Ok so I bought a 2000 gtp last night ran good on the hour and a half drive home went out this morning to start it and it started running really rough so I went to work and when I got back I started it and it was running perfect so I went ahead and put new plugs wires and fuel filter and also added a cold air intake..
    Then it started doing it again after driving it for a while so I scanned it and it shows cylinder 3 injector circuit open. And cylinder 3 misfire so could you guys help please
    And if I do need a new injector should I buy a whole set of aftermarkets or just buy one new stock one??
  2. #2 Re: I'm a Noob and need injector help please!!
    Apr 2009
    Fort Worth TX
    Check the wiring to that injector.
    With the key on the +12 volt wire should be hot for all injectors.
    Swap injectors - #3 with #5 or #1 and see if the DTC follows.
    If DTC follows then replace the injector.
    If you still have an open circuit on #3 then there's a problem with wiring or PCM.
    Other things you could try with the injector in hand:
    Check the resistance across the two injector leads. It should be about 13 ohms or something.
    OL or infinite resistance means the coil is open (open circuit).
    Take a 12 volt power supply and connect it to the injector. Situate the wires before turning the power on.
    It should make a "click" sound.
    No "click" means the coil is open (open circuit).
  3. #3 Re: I'm a Noob and need injector help please!!
    Aug 2012
    Cushing, OK
    Thank you I will go try all those things the thing that is weird to me is it'll run fine for a while and then crappy for a while and vise versa if it is the computer how much will that set me back?
  4. #4 Re: I'm a Noob and need injector help please!!
    Circuit open means its unplugged usually.
  5. #5 Re: I'm a Noob and need injector help please!!
    Aug 2012
    Cushing, OK
    You are right on the money went out this morning and pulled the plastic cover off the motor. I noticed when I wiggled the injector plug one way it smoothed out so I pulled it off and cleaned it up and put some dielectric grease in it and shes running awesome now
  6. #6 Re: I'm a Noob and need injector help please!!
    glad to be of service.
  7. #7 Re: I'm a Noob and need injector help please!!
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I had an injector missing on my GTP just last week. Go to a shop or if you know a mechanic that has a computer that reads codes, like a Tech2?? I think that's what they are called, or something like that, but you can hook it up to the wiring in your car and get a reading, also, take off the supercharger cover and unplug the wires that lead to the 3 missing injectors, the white, plastic plugins could be oozing fuel back up into the outlet, which is a sign that it's the injectors. My car was running sporadically too, it was an easy fix though.
  1. 04 gtp injector.
    By Toms04compg in forum General Tech Discussion
    Last Post: 04-18-2012, 11:34 AM
  2. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
  3. injector scaler
    By impalamike3800 in forum PCM Tuning
    Last Post: 06-09-2009, 03:22 PM
