Thread: Weird sounds when A/C is on
Results 1 to 10 of 10
  1. #1 Weird sounds when A/C is on
    SE Level Member cardiffGIANT98gtp's Avatar
    Kansas
    So i noticed the other day that when i have the a/c on my car makes a bad sound that gets louder as the rpms rise.
    Reminds me of an electric motor winding up or something. Its not really horrible sounding but it just doesn't sound like something that should be normal.
    I added some oil and refridgerent to the system. It got a little quiter but it's still there. My car has close to 150k on it now so i figure its probably just the compressor going bad.
    Just wondering if anyone has any ideas.
  2. #2 Re: Weird sounds when A/C is on
    Jul 2012
    Chicago
    My car does the same thing but only on days where it's above 90*. It comes and goes and has been doing so for over 3 years. Never gave me any problem.
    -Carl
  3. #3 Re: Weird sounds when A/C is on
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    Mine does the exact same thing. Been doing it for a while and the ac is still running. Kind of like a wining grinding noise.
  4. #4 Re: Weird sounds when A/C is on
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    lol if u want a compressor i have a used one i will sell ya
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Weird sounds when A/C is on
    GT Level Member GMCustomerService's Avatar
    Michigan
    Quote Originally Posted by Nathan07GP View Post
    Does it only occur when the A/C is on? The compressor may be a possibility.
    If it is more of a high pitch whine, it may be related to the temperature actuator shaft. These are just suggestions, not a diagnosis.
    Consider having the vehicle inspected by a certified technician for an official diagnosis. Please keep us posted.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  6. #6 Re: Weird sounds when A/C is on
    Dec 2008
    Lawndale, CA
    I know this is an old thread but figured I would bump this up. I have been having the same kind of issue with my AC lately. When I turn on the AC and the car is just under 1K rpms and the car is in drive, it makes an aweful noise. Almost sounds like something is lose and vibrating. As soon as I turn the AC off by pressing the button on the HVAC the sound goes away. Not really sure what it is. Not sure if it is just out of refridgerant or oil. The air is still cold that is blowing inside when it is on. The car just started doing this. I am going to try one of those recharger kits to see if it does anything.
    Any thoughts from others?
    Thanks
    -Mike
  7. #7 Re: Weird sounds when A/C is on
    St. Louis
    Sounds like the bearings in the A/C clutch to me. Take a look at the compressor and see if you see any small metal shavings on it.
  8. #8 Re: Weird sounds when A/C is on
    Dec 2008
    Lawndale, CA
    I took a better look today after work. The sound is coming from the tensioner.
  9. #9 Re: Weird sounds when A/C is on
    St. Louis
    Good deal. Whole lot cheaper to replace.
  10. #10 Re: Weird sounds when A/C is on
    Dec 2008
    Lawndale, CA
    Yup that's exactly what I thought. I will replace it with a new dorman unit.
  1. More Sounds...
    By Remnant King in forum General Tech Discussion
    Last Post: 02-17-2012, 01:10 PM
  2. GT sounds like a gtp?
    By betsgtp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2010, 09:20 PM
  3. Supercharger sounds weird when AC is on
    By eXceL(FAM) in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2010, 11:52 PM
  4. Engine weird sounds/chugging
    By ajm786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 09:18 AM
