Thread: Pushrod Damage...should I replace?
Results 1 to 12 of 12
  1. #1 Pushrod Damage...should I replace?
    Oct 2011
    Puyallup WA
    So didn't notice it when I pulled it apart but I am installing my xp cam and 5 of the pushrods have damage all in the same place...previously I had zzp 1.9 rockers and never noticed any noise ran great...need opinions!
    08 G8 GT - exhaust Tune
  2. #2 Re: Pushrod Damage...should I replace?
    I wouldn't think you need to replace for that. Although I'd be looking in the head to see if there's a corresponding shiney mark.
  3. #3 Re: Pushrod Damage...should I replace?
    I had some like that when I swapped my motor
  4. #4 Re: Pushrod Damage...should I replace?
    hangover park IL
    its from it hitting the head casting flash near the inboard (towards rocker fulcrum) side of the pushrod hole.
    seen it plenty of times.
    pull off the head and grind the casting parting lines/flash in those area's
    its sorta hit or miss...most times there's clearance, sometimes there isn't. it doesn't help that improper securing procedure of the rocker stands could contribute to the rockers being offset and making it worse/better
    ~James~ Psychotic Gearhead
  5. #5 Re: Pushrod Damage...should I replace?
    Feb 2009
    flintnasty MI
    Last I knew zzp warned you cant run 1.9s on a l32 l26
  6. #6 Re: Pushrod Damage...should I replace?
    Oct 2011
    Puyallup WA
    Yeah the casting around some of the pushrod holes is really rough and after I put the stock rockers back on clearence is small in those rough areas...I'm going to reuse them and order up some new ones to add to my parts collection...if zzp did have issues with 1.9's on the l32 motors that could be a contributing factor
  7. #7 Re: Pushrod Damage...should I replace?
    May 2013
    RI
    I had the exact same marks on mine after running 1.9's on an L32 for about 1000 miles. I reinstalled with the flattened part towards the lifters, and I pulled them again after another 25k and they looked exactly the same.
  8. #8 Re: Pushrod Damage...should I replace?
    Oct 2011
    Puyallup WA
    Well 1.6 rockers are back in so hopefully won't have anymore issues...1.9 will be going in a l67
  9. #9 Re: Pushrod Damage...should I replace?
    hangover park IL
    well dont forget that by now it may have shaved everything off and you have clearance....and metal particles
  10. #10 Re: Pushrod Damage...should I replace?
    Oct 2011
    Puyallup WA
    Yeah rockers where on car for prob 20k so metal particles started 2 years ago
  11. #11 Re: Pushrod Damage...should I replace?
    Jan 2013
    Australia
    she'll be alright
  12. #12 Re: Pushrod Damage...should I replace?
    Oct 2011
    Puyallup WA
    Yeah I got her back together has a good untuned lope
  1. stock pushrod length?
    By Maximum Gnarnage in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2012, 01:48 PM
  2. pushrod
    By Toms04compg in forum General Tech Discussion
    Last Post: 07-18-2012, 01:37 PM
  3. Pushrod length question
    By dwc1435 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-18-2012, 08:26 PM
  4. xpz cam pushrod length locations?
    By theonlysi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 02:22 PM
  5. Pushrod length?
    By ABSTIFFGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2009, 11:27 AM
