Thread: Gen V W/ Gen 3 Intercooler Core
Results 1 to 11 of 11
  1. #1 Gen V W/ Gen 3 Intercooler Core
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Just got a Gen V yesterday and wanna swap it with my current Gen 3 on my zzp stage 2 intercooler setup. How do i get the Gen V ready so i can replace my gen 3 with it? What needs to be done to the gen v? Thanks.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Gen V W/ Gen 3 Intercooler Core
    Jan 2009
    Tallahassee, FL
    The outlet will be a little offest I believe and you'll need a TB adapter. Other than that it bolts right on.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    You will need the Gen 5 bolts from zzp. The Gen 3 bolts for the S2IC are not long enough. But it fit perfect together. I have the ssic Gen 3 core on my Gen 5.
    Sent from my Galaxy Nexus using Tapatalk 2
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
    Bowie, MD
    Okay cool. Thanks guys. Do I have to block anything off on the gen v? Seen some weird and new things that arent on my gen 3 and also I will be using my stock ported l67 Tb.
    Sent from my SGH-T989 using Tapatalk 2
    Quincy, Mass
    I sent you a pm on cgp w a link to the intercooler write up and check the genV stickie thread on there too, lots of good info.
    If you are using a breather then you want to run a vac line from the nipple on the back of the genV to the tb. If you are doing the breather less mod then just cap that nipple off. If you are going to run the gen V evap then you'll need to flip the tb adapter upside down or the throttle cables will hit it. If you don't use it then youll have to tap and plug that hole.
    No more GP 04 Impala SS Indy:
  6. #6 Re: Gen V W/ Gen 3 Intercooler Core
    Quote Originally Posted by Swiggles View Post
    the nipple on the back of the genV is blocked by the genIII core IIRC so it wouldn matter if you ran a line from it to the TB or not if youre running a breather with the setup...
  7. #7 Re: Gen V W/ Gen 3 Intercooler Core
    Bowie, MD
    I didnt plan on running a valve cover breather. What should i do then since the nipple is blocked by the gen 3 core?
  8. #8 Re: Gen V W/ Gen 3 Intercooler Core
    Bowie, MD
    Thanks swiggles
    Apr 2012
    Middletown DE
    Quote Originally Posted by gtpsleeper View Post
    Heh I guess that's why my car does that little sputter thing when I turn it off. Guess I need to make something to fix that.
    1993 Oldmobile 88
  10. #10 Re: Gen V W/ Gen 3 Intercooler Core
    Again do your research on this as Im trying to remember the research i did before I made my switch but in order to have a functioning non breather setup on a genIII core, you have to drill into the LIM somehow and re-route it to the valve cover then have one run behind the maf or something somehow...
    Basically, after I read how to do it, I decided it would be easier just to breather it. Just cap everything and run a breather is what I ended up doing because keeping the vac system with a genV on a genIII core is a PITA...
    Quincy, Mass
    If your not doing the breather then do this
    http://www.grandprixforums.net/showthread.php?t=44478
    But if the rear pcv is block then I think you need to run a front cover in the back with a breather or drill a hole and add a breather to the rear cover. I'm not 100% sure about that though. You might also be able to drill a small hole in the core if there is room to move the pcv hole over.
  1. Intercooler core install?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-21-2012, 10:50 PM
  2. ZZP intercooler core charges
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2011, 11:19 AM
  3. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
  4. Prj intercooler core
    By sic6 in forum General Tech Discussion
    Last Post: 04-21-2010, 12:43 AM
