Thread: Rough Idle with intermittent idle miss
Results 1 to 11 of 11
  1. #1 Rough Idle with intermittent idle miss
    Aug 2012
    Danville
    I have a 1999 GTP I purchased about 9 days ago with 114,000 miles, and I've gone through a lot of tune-up procedures and am getting a stumbling/missing at idle both in park and in drive when idling only. So far have have replaced the fuel pump, fuel filter, MAF sensor, spark plugs, wires, cleaned the IAC and PCV with carb cleaner, replaced fuel filter and put synthetic oil with new oil filter. It runs great and gets real good gas mileage but at idle after car warms up and settles down to about 800 rpms, it starts stumbling/missing and varying the idle about 200 rpms.
    I have seen quite abit of other members with rough idles but not sure what else to try to fix it.
  2. #2 Re: Rough Idle with intermittent idle miss
    Pennsylvania
    I have a freshly cleaned tb, fresh MAF, full seafoam treatment, new spark plugs all around, just replaced all vacuum lines including the booster cap itself and when I start the car hot, within 20 seconds of start up, my aeroforce was showing 26 misses. Didnt get a chance to check out which cylinder(s) were missing.
    I knew it was happening before I got the gauge though cause when I start it hot sometimes (not all the time) I can feel the rough idle and I can hear the intermittant coughing from the exhaust.
    Once I start driving though it all calms down.
    Im stumped, good question, lol.
    Sport Edition Kv5 18x8
  3. #3 Re: Rough Idle with intermittent idle miss
    Pennsylvania
    Vacuum leak perhaps. Most popular spot is the dry-rotted rubber T off the LIM on the left side, under the supercharger snout.
  4. #4 Re: Rough Idle with intermittent idle miss
    Aug 2012
    Danville
    Thanks SlowNA06. I did check the vacuum hoses and did not see anything obvious. The T under the supercharger snout looks like new and I check it and it seems tight. It still could be a vacuum. I disconnected a vacuum hose and the idle raised up a bit. Not sure how to check vacuum to know if it is the cause.
  5. #5 Re: Rough Idle with intermittent idle miss
    What plugs and gap?
  6. #6 Re: Rough Idle with intermittent idle miss
    Pennsylvania
    Yeah, browser killed my other response. If you're using Bosch, E3, or Champion spark plugs, stop and do something else.
  7. #7 Re: Rough Idle with intermittent idle miss
    Houston
    Are you modded? Seems modded GP's like to do this. I know mine does, but only at idle. From what I've been told, if its not triggering a blinking SES light, it's nothing to worry about. Since you just purchased it, and you're not sure if it's been modded, post some pics of the engine bay.
  8. #8 Re: Rough Idle with intermittent idle miss
    Aug 2012
    Danville
    Thanks for the responses. The car is stock, right down to the paper air filter. I will take a picture of the engine after work and attach it. I have the Champion Spark Plugs - 7940's (CCGE double platinum) in it now gapped at .058". I wanted to wait until I do the seafoam engine treatment before I put the Iridium plugs in. I have seafoam in the gas tank right now. I have a scan guage attached to it and it is not throwing any codes.
  9. #9 Re: Rough Idle with intermittent idle miss
    Pennsylvania
    Quote Originally Posted by 99GTPMLA View Post
    That brand causes misfires. Congrats, you found your problem (or one of them).
    Platinum plugs cause misfires eventually (durability issue).
  10. #10 Re: Rough Idle with intermittent idle miss
    Pennsylvania
    If you're playing by the wallet, seafoam it with Autolite 606 copper cores in. They're <$2 each.
  11. #11 Re: Rough Idle with intermittent idle miss
    Those plugs can surely cause the problem.
    Once you do whatever your going to do, swap the iridiums in there and see whats its like.
  1. Intermittent start/ low idle,shut off
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2011, 10:20 PM
  2. Cold Idle Miss
    By farmtwin in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-18-2010, 09:04 AM
  3. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
  4. 91 GP rough idle
    By Juanmiguel in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-04-2010, 11:07 PM
  5. Wased my engine at the car wash 2 weeks ago, still have miss at idle.
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 05:59 PM
