Thread: Intermittent start/ low idle,shut off
Results 1 to 7 of 7
  1. #1 Intermittent start/ low idle,shut off
    Florida
    Ive been having this problem from time to time but it seems to happen more often now. Sometimes when i start my car it immedietly idles high but then it falls real low almost to 0 rpm then it idles normal.But at times including once today I started it and it then it shutoff.The second start was fine. I dont know what is causin this it seems to happen after it sits for a while but my thought may be fuel or possible another vacuum leak.Any thoughts?
  2. #2 Re: Intermittent start/ low idle,shut off
    Florida
    No help?
  3. #3 Re: Intermittent start/ low idle,shut off
    Kansas
    What have you all done? Checked for vac leaks? Cleaned TB?
  4. #4 Re: Intermittent start/ low idle,shut off
    Florida
    i checked for vac leaks but so far none.Last time i cleaned my TB was back in spring so pretty recent. Could be a dirty MAF? My mechanic also mentioned it could be the egr pinnale? He told me to just take apart the egr and spray it with carb. I just wanna know what to look for.
  5. #5 Re: Intermittent start/ low idle,shut off
    SE Level Member jarkayman's Avatar
    Aug 2011
    CNY
    You could unplug the MAF sensor and see if it still does it.
  6. #6 Re: Intermittent start/ low idle,shut off
    St. Louis
    How about checking the IAC since this appears to be at startup. Might be sticking hence the strange idle/stall issue.
  7. #7 Re: Intermittent start/ low idle,shut off
    Florida
    ^Thats possible.forgot about that
  1. Intermittent no-start when key turned.
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 10:00 AM
  2. 3.8L SC Random stalls, faulty intermittent start!
    By agentbluescreen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 01:22 PM
  3. 97 GT intermittent start please help
    By airhead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2010, 09:23 AM
  4. 97 GT intermittent start
    Last Post: 07-01-2009, 06:43 AM
  5. PK III and Remote start...auto shut down grrr
    By mongo in forum General Tech Discussion
    Last Post: 08-07-2008, 06:37 PM
