Thread: Engine Reassembly Help.. L67 lots of pics
Results 1 to 20 of 54
  1. #1 Re: Engine Reassembly Help.. L67 lots of pics
    Apr 2009
    Fort Worth TX
    1. Do i put copper spray on the head gasket? i have the felpro gaskets.
    Go for it. Some people swear by it. I always use it on a rebuild. Don't spray the deck or the heads, just both sids of the gasket then install.
    2. How do i know which push rods go were i took them out to clean them and idk were to put each of them or if there even different in size?
    Always put them back in the same holes they came out of. The wear pattern on the tips are particular to each rocker and lifter.
    There is no way of telling what hole they came out of it you mixed them up.
    3. What do i use to clean the surface of the heads and block? degreaser?
    Razor blade and some MEK or acetone.
    4. One of the heads has a small chip by the valves should i worry its a junk yard pulled motor from a 97 gtp.
    Take a Dremel tool with a barrel sander and knock the edges down. If you don't do this it will create detonation in that cylinder.
    5. I have the torque to yield bolts for it with a paste on them idk if those are ok for the heads, since i've heard debates about paste and teflon tape and i dont want my heads leaking coolant or anything at all.
    Put the bolts in and TTY them. They already have a sealer on them. Make sure they are brand new OEM fasteners.
    6. Any other info is appreciated and thanks in advance.
    If the motor was running well when you disassembled then there should be no problem but to be safe take the block and rods to a machine shop and have them checked for OOR and mains alignment. If the block is out of spec it may run for about 5 minutes and FAIL.
  2. #2 Re: Engine Reassembly Help.. L67 lots of pics
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Quote Originally Posted by Rico View Post
    1. will do i have some already
    2. Thats the problem i did mix them up when i cleaned them so how can i solve this?
    3. What about gas?
    4. just slightly? never done work on heads to scared of disrupting any air flow or causing problems with the heads since ive heard its a delicate process
    5. Got them from O'reilly also isnt there a torquing procedure at 90 Degrees?
    6. Trying not to put much money into i will be taking the oil pan off to see if there is any material in there but so far it seems good. Also according to a friend i have at the junk he said it was running before they pulled it in.
  1. 04 GTP - Transmission build started!!
    By ADrugDealer in forum Members Rides
    Last Post: 06-05-2015, 11:34 PM
  2. New Pictures (LOTS OF PICS)
    By Fivefingerdeathpunch in forum Off Topic Discussion
    Last Post: 08-11-2010, 09:29 PM
  3. Wheels on/Sd air dam on!! lots of pics
    By glanzergtx in forum Tires & Wheels
    Last Post: 05-02-2009, 01:01 AM
  4. Where my $$ has gone..lots of pics
    By TJs97 in forum Visual/Body Modifications
    Last Post: 03-10-2009, 09:32 PM
  5. Lots of pics of my stock GTP
    By rfmgtp02 in forum Visual/Body Modifications
    Last Post: 11-06-2008, 10:45 PM
