Quote Originally Posted by jfonger95 View Post
Yes it ran just fine at one time with the same exact mods i have today...then the mass air flow went out due to SPECTRA Air filter. i got a new mass air flow and then my 02 sensor went bad. then i started getting black smoke due to the burning of to much fuel. I replaced the mass air flow and the o2 along with the wiring...both MAF fuses went out so i replaced them both and it ran much better. After that my CPS went out. it was hesitating real bad. I had zzp check the wiring and throw a used one in there which made it run even better. All there is left is that coughing when i accelerate. I noticed that the spark plugs we not gapped correctly so i took them all out and put brand new ones in gapped at .040. it did nothing...
used crank sensor? put a new one in. while your there, re check the wires, especially at the plug. if that code keeps coming up, id lean towards that sensor or wiring to it. and clean everything up real good behind the balancer too.
