Thread: GM S/C Gasket Question
Results 1 to 18 of 18
  1. #1 GM S/C Gasket Question
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I called The Local Stealership today and ordered 2 GM S/C gaskets with employee pricing. Uncle brought them to me and well they are not the correct gasket... I think. This is for the GEN3 blower/lim but from researching I can only find one part number for the S/C gasket on the 3.8. Is the right Do I have to cut the gasket to fit? I did tell the person over the phone that it was a 2004 GTP I needed them for.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: GM S/C Gasket Question
    Charles City, IA
    Thats the right gasket....
    SMGPFC Two Nipple General
  3. #3 Re: GM S/C Gasket Question
    Grand Island, Nebraska
  4. #4 Re: GM S/C Gasket Question
    Jan 2012
    Philadelphia
    it might not fit because of your IC
  5. #5 Re: GM S/C Gasket Question
    Apr 2012
    Middletown DE
    Quote Originally Posted by TheOtherNick View Post
    Can't be it covers up over an inch of the intake hole
    1993 Oldmobile 88
  6. #6 Re: GM S/C Gasket Question
    You use RTV to seal an intercooler up top. Seal it to the LIM with the gasket and RTV.
    Who knows, just cut the crap out of it.
    Are you using a L67 or L32 LIM?
    GenIII or GenV blower?
    GenIII or GenV IC core?
    Oh the fun.
  7. #7 Re: GM S/C Gasket Question
    Apr 2012
    Middletown DE
    Oh the fun.
    L32 LIM
    GenV
    GenIII
    I have a Garlock on there now that ZZP Custom Cuts so the intake holes are matched to the LIM, That is why I thought the hole should have been bigger. Looking at Intense's website they have pictures of the L67/L32 GM gaskets and yeah theothernick is correct.
    ZZPerformance - Garlock Supercharger Gaskets #MT-SCGGAR
    1993 Oldmobile 88
  8. #8 Re: GM S/C Gasket Question
    Jan 2012
    Philadelphia
    other wise known as garleak's
  9. #9 Re: GM S/C Gasket Question
    Jan 2012
    Philadelphia
    i have them too lol
  10. #10 Re: GM S/C Gasket Question
    That is the early version Gen V gasket where the LIM had the recessed areas for the coolant port O-rings. The newer design is metal with inlaid rubber and the LIM had a flat surface around the coolant ports. Therefore it didn't get the big bulky o-rings.
    Being IC'd, I wouldn't use any premade gaskets. 2 rolls of gasket material and some permatex 26B is the way to go.
  11. #11 Re: GM S/C Gasket Question
    Apr 2012
    Middletown DE
    I will do this. Seems like it should work and would be more flexible than GM gaskets
    1993 Oldmobile 88
  12. #12 Re: GM S/C Gasket Question
    Search on me and either 26 or Matt and that info. I think he put it up or posted about how I do the process etc. It's here probably 10 times
  13. #13 Re: GM S/C Gasket Question
    Apr 2012
    Middletown DE
    Eh I have the gaskets and they cant be returned. I will cut them and RTV with what Bill suggested.
    1993 Oldmobile 88
  14. #14 Re: GM S/C Gasket Question
    Best of luck..that's not just a paper gasket you have there. You have a carbony type gasket with metal inside it.
  15. #15 Re: GM S/C Gasket Question
    Apr 2012
    Middletown DE
    Ehh I dont like when you say good luck lol. I tried to find somethign about the way you do the RTV gaskets but only found threads where you told people about it..
    1993 Oldmobile 88
  16. #16 Re: GM S/C Gasket Question
    Portland Oregon
    You can cut those gaskets just fine. Scribe them with a razor knife and make about 3 passes and you're through. I've run Gen V gaskets on the top and bottom of my intercooler and just a dab of RTV at the corner where you have to cut through the viton and it runs fine every time
  17. #17 Re: GM S/C Gasket Question
    I thought there was metal in there. Learning something new!
    Apr 2012
    Middletown DE
    It has metal. I'm cutting them with my dremmel.
    Sent from my Galaxy Nexus using Tapatalk 2
    1993 Oldmobile 88
  1. lim gasket question
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-21-2012, 05:57 AM
  2. LIM Gasket Question
    By zackp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2012, 07:23 PM
  3. which gasket set? and question about rebuilding
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2012, 05:24 PM
  4. Head gasket kit question
    By ssheely220 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2011, 04:34 PM
  5. 98 L36 LIM gasket question
    By IffyG in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2011, 07:13 PM
