Thread: Couple quick questions
Results 1 to 10 of 10
  1. #1 Couple quick questions
    gardner,mass
    Ok so i need to replace my cat so im going with the zzp downpipe, now my question is is a 2000 gtp 2.5 at stock?
    Also i want to block off my egr cus its given me nothing but problems from the start so can i just block it off or will it throw codes without deleting it from the pcm?
    Thanks in advance
  2. #2 Re: Couple quick questions
    Pennsylvania
    The stock dp is more like 2" ID stock, it's really small, even 2.5 is a nice upgrade... Most people go 3" if you're gunna be modding a gtp
    Sport Edition Kv5 18x8
  3. #3 Re: Couple quick questions
    if you remove the egr, yes your cel light will come on. you would need to have it tuned out to not set the code.
  4. #4 Re: Couple quick questions
    Pennsylvania
    Also, I believe there are some write ups in the how to section on egr delete
    If you don't care about it being there you could probably just unplug it and leave it there to disable it
  5. #5 Re: Couple quick questions
    Quote Originally Posted by FriboRage View Post
    only problem with the light being on all the time is, you dont know if something new has popped up on you.
  6. #6 Re: Couple quick questions
    gardner,mass
    so i can fit a 2.5 or 3 on a stock application?
  7. #7 Re: Couple quick questions
    gardner,mass
    also i live in mass and laws suck so i would not be able to get a sticker next year if the egr code is there
  8. #8 Re: Couple quick questions
    Pennsylvania
    If you're gunna stay stock then yeah maybe just stay 2.5, if you think you might go farther in the future it wont hurt to have 3"
    Have you thought about how to tune the code out? Most aftermarket pcms come with codes like that disabled or you can request it.. Then since you'll be getting a tuned PCM it would probably benefit to go 3"
    Thats the way I would see it.
  9. #9 Re: Couple quick questions
    ZZP catted downpipe may still throw a cat code, because the high flow cat flows way more than the stock one.
  10. #10 Re: Couple quick questions
    Apr 2009
    Fort Worth TX
    How about this for the EGR?:
    Repair it so it works correctly.
    It's a very simple system; valve and tube that goes to the LIM.
    Make sure the valve is working and the tube isn't clogged.
    You can score a valve at a junk yard for cheap. If your tube is cracked grab that as well.
    It only takes about 5 minutes to install this stuff.
    If that doesn't fix the problem then replace the MAP sensor.
  1. Couple Questions!
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 08:30 PM
  2. couple of questions
    By selliott in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2010, 12:53 PM
  3. couple of quick questions about tstats
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 02-02-2010, 11:05 AM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. couple of quick downpipe questions.
    Last Post: 03-18-2009, 07:36 PM
