Thread: Low Boost
Results 1 to 9 of 9
  1. #1 Low Boost
    Apr 2012
    Wyoming, MI
    Recently, the digital gauge thing in my 2000 GTP isn't showing full boost, like it used to, and my car his having a more rough idle. What could be the cause?
  2. #2 Re: Low Boost
  3. #3 Re: Low Boost
    GTX Level Member blackflag's Avatar
    Virginia
    My guess would be vac leak. check your houses.
    edit- you beat me
  4. #4 Re: Low Boost
    P0171.
    Embrace it.
  5. #5 Re: Low Boost
    GTP Level Member buickman104's Avatar
    NYC
    When my buddy's Boost Bypass Valve broke he couldn't get more than 3 to 4 pounds of boost regardless of pulley size on the blower.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: Low Boost
    ^ rough idle gives away that it's a vacuum leak, not just a busted BBV solenoid.
  7. #7 Re: Low Boost
    Quote Originally Posted by buickman104 View Post
    I agree, minus a toast BBV doesn't cause a crappy idle.
  8. #8 Re: Low Boost
    Apr 2009
    Fort Worth TX
    In unison.
  9. #9 Re: Low Boost
    Apr 2012
    Wyoming, MI
    I checked everywhere and cannot find a vacuum leak (carb cleaner trick). It only idles slightly rough, not as smooth as i want. And the boost only goes up to 90% on the digital gauge.
  1. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  2. Boost DIC
    By 99gp in forum General Tech Discussion
    Last Post: 02-27-2011, 11:25 AM
  3. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
