hey everyone, i bought a ZZP ported LIM from a member on here. i got a pretty good deal on it and would like to make it work. as many of you know i have a 97 GTP and have a GenV with a S2IC. i know this is the ZZP Gen III S2/S3 LIM, i should have looked more into it before i bought it. the guy said he ran it on his car with the GenV and S2IC witch i dont see how he did..
but here we go i tried to make this organized and easy to understand and for suggestions. each picture is # at the top right in yellow 1-3.
#1
1. blue circle: PCV- this is not the same as the GenV PCV set up so it wont work? what should i do.
2. red arrow: this looks a little hogged out more then the GenV LIM, will this matter (loss of performance, etc..)
3. purple arrow: this area looks a little hogged out more as well is this a problem?
4. green arrow: what is this?
#2
1. blue circle: the gasket doesn't look to line up perfectly with the PCV valve is this a problem?
2. black/purple circle: what is this area, there is a whole in the gasket but nothing there in the LIM
3. black arrow: im guessing i need to machine out this area to match the bottom of the IC core correct?
4. yellow ?: there is nothing there under the gasket should i cut out the gasket around the LIM inlet?
5. red square: this piece is blocked off on the LIM should it be that way?
6. red circle: should this area match the gasket?
#3
1. yellow circle: what should i do about this area?
2. blue circle: what do i do about this area?
3. red line: this area doesn't seem to match up with the LIM the LIM inlet looks bigger. should i trim the gasket to fit?
-this is a pic from ZZP i have the GenIII S2IC LIM and im suppose to have the GenV S2IC LIM
can i get this LIM to work with my set up?
would it be easier to sell this and machine my own or buy one already ported for a S2IC GenV?
i took my time and tried to make this as easy as possible to understand,
any help would be greatly appreciated!
thanks in advance,
Eddie
