Thread: Need info for buying a radiator, ac condenser, and new fans
Results 1 to 5 of 5
  1. #1 Need info for buying a radiator, ac condenser, and new fans
    Jun 2011
    Oklahoma
    I want to buy an all aluminum radiator, and two 3,000 CFM fans, as well as an ac condenser. The car is a 98 GrandPrix GTP, 3.8 s/c all stock. I've always had high heat issues with this car, my current radiator is a ready rad from Advanced Auto Parts, it is 1 year old and get this the plastic tanks are perfectly fine, but somehow it sprung a leak from the bottom portion of the aluminum of the radiator, I didnt overtighten any bolts, so thats not the issue. I think this radiator was just not built very well, plus its made in mexico. So im getting my money back for it. I just really want some really good cooling parts. I've checked pfyc.com, w-body.com, zzperformance.com, 3800performance.com, ebay.com, and I can't find the parts i'm wanting. Here it is again (All Aluminum Radiator, two 3,000 CFM fans, and an A/C Condenser) If I need to do some customizing to fit this stuff, I really dont mind. I've torn this car apart, and put it back together so many times, I very comfortable customizing things to fit, and work the way they should. Thanks for all the info you can give me.
  2. #2 Re: Need info for buying a radiator, ac condenser, and new fans
    Jun 2011
    Oklahoma
    Also i'd like the radiator to be 1 inch - 1 5/8" thick dual core.
  3. #3 Re: Need info for buying a radiator, ac condenser, and new fans
    Jan 2012
    Philadelphia
    you didn't want the ZZP over sized aluminum radiator? i heard they were pretty good, if you just want stock since your car is stock call 1-800-RADIATOR, if they're in your area a new one is like $130.00
  4. #4 Re: Need info for buying a radiator, ac condenser, and new fans
    Jun 2011
    Oklahoma
    Not really, because the tanks are plastic. I want something that will last longer, and be very reliable. I'm not doubting the quality of of thier radiators, I just dont want any plastic. The only problem is finding the radiator I want for this car is very difficult, you would think they would've made them an upgrade for the serious racers/modders. But I guess they are still using ones with plastic tanks.
  5. #5 Re: Need info for buying a radiator, ac condenser, and new fans
    You may be aiming down a custom path. I don't believe anyone currently makes radiators for W bodies that are all aluminum.
  1. Radiator Fans
    By Garry in forum General Grand Prix Discussion
    Last Post: 05-18-2012, 09:08 AM
  2. radiator fans not working
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 07:59 PM
  3. cant get radiator fans to work
    By rocknkroll in forum General Tech Discussion
    Last Post: 05-05-2011, 07:51 AM
  4. Should my radiator fans be on all the time?
    By yekimmrt in forum General Tech Discussion
    Last Post: 12-20-2010, 07:26 AM
