Thread: Fueling issue?
Results 1 to 6 of 6
  1. #1 Fueling issue?
    Florida
    Im gonna try and make this short. 04 GTP has an occasional rough idle upon startup but rough idle everytime i fill up gas tank, like to full and start it up right after. Other symptoms; i seem to burn thru gas a bit quicker then usual but im tracking it on the DIC starting today just to make sure, and around 2 of the injectors is wetness on the LIM as if fuel may be leaking.? Im running premium 93 octane like im supposed to, car just turned to 98k, and no other symptoms besides those 3 above. Any ideas? oh no codes either.
  2. #2 Re: Fueling issue?
    SE Level Member Joe Perez's Avatar
    Jul 2012
    Douglas AZ
    I replaced the vapor canister on mine and it help
  3. #3 Re: Fueling issue?
    Clean the TB yet?
    And maybe the evap system is causing some sort of problem when you fill your tank full.
  4. #4 Re: Fueling issue?
    Jun 2011
    Oklahoma
    Canister Purge Solenoid Vent Valve, mine was doing the same thing except it got to a point when I would fill the tank up completely, it would have a very rough time starting, had to build up a lot of fuel pressure before it would start. It also caused my car to get terrible gas mileage. The wetness by the fuel injectors worries me a little, take a Q-tip, or use your finger if it fits in that space, and smell the liquid to see if its fuel, or something else. lol... Best advice I can give you on that one.
  5. #5 Re: Fueling issue?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    I think I'm fight that problem now... I put halff a tank and won't start now.... have been gettin evap codes since the car is runnin
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  6. #6 Re: Fueling issue?
    Florida
    Yea forgot to mention at times it takes a few extra seconds to crank it up then its followed by a rough idle.
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. Fueling
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-11-2011, 08:22 AM
  3. over fueling?
    By savannaz34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 02:23 AM
  4. '04 GP GT - 2 Questions, Fueling and start up related.
    By Ryan04GPGT in forum General Tech Discussion
    Last Post: 03-19-2009, 04:16 PM
  5. another kr issue
    Last Post: 02-24-2009, 12:30 PM
