so backround i put a l67 from a 98 bonneville in my 97 grand prix gt ( yes i know that i have the crappy tranny) i have installed a few things such as ported exhaust, ceramic coated crossover pipe throttle body spacer etc. i have aa pcm through zzp thats seems to be an o.k. tune
im slowly trying to troubleshoot and discover the problem but unsure if any one else already knows the answer. the car stalled out and i found fuel in oil. changed oil to avoid bearing wash and checked fuel pressure regulator and it seemed alright. two days later stalled again i got it started again with some difficulty and it was clanking from the front of the motor by cylinders 1 and 3. as i inspected it belts chirped and motor locked up we trailered it and looked at it later. motor was cranking again and it runs again smoothly. horrible clanking from cylinder 1,3 area. i checked plugs and only cylinder 3 smelt like it was doused with gas so possible flooding. checked compression and had about 150 on all cylinders except 127psi on cylinder 3.
im thinking possibly injector tip broke off in cylinder 3, timing jumped, or wristpin or rod on clyinder 3.
all thoughts and sugestions are encouraged and gladly accepted
thanks guys
