Thread: FPR problems?
Results 1 to 8 of 8
  1. #1 FPR problems?
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    What would cause my car to be going on it's 3rd Fuel pressure regulator? All the vac lines that connect to it are new, Maybe the sending unit? I can't for the life of my find anything that would cause my car to be burning through them every 4k miles....
    New project: 2000 Red GTP.
  2. #2 Re: FPR problems?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    What makes you think its the regulator? The pressure in the regulator can be checked by pinching the fuel return line. If the pressure in the fuel pressure regulator does not rise after pinching the fuel return pipe, it is an indication of a bad fuel pressure regulator.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: FPR problems?
    NC
    I also thought that if you smelled gas in the vac lines it was bad. Either way, when I replaced it the first 2 times I would get amazing MPGs, now I can drive 5 miles on a quarter tank of gas (the truth) and everytime I replace that FPR, BAM 20+ mpg.
  4. #4 Re: FPR problems?
    Hagerstown,Md
    Mine smells like gas. If it has visible gas pouring from it then the diaphrams shot in it. disconnect the hose have some one bump the ignition or start the car and see if gas comes out of it. Id just piont the hose away from a flamable source and your face. Seeing what your fuel pressure is would be really helpful
  5. #5 Re: FPR problems?
    NC
    I'll have to try it and see. It also sounds like my fuel pump has gotten louder and has more of a hiss/whine to it?
  6. #6 Re: FPR problems?
    GT Level Member rolyat's Avatar
    OKC
    A louder fuel pump could indicate something is clogged. Just out of curiosity, when is the last time the fuel filter was replaced?
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  7. #7 Re: FPR problems?
    Charles City, IA
    Didnt you say before you got them out of the junk yard? There is your problem.
    SMGPFC Two Nipple General
  8. #8 Re: FPR problems?
    NC
    Quote Originally Posted by rolyat View Post
    about 1 month ago
    I got a new one, and so far so good, but we'll see.
  1. gtp problems
    By twinturbogto in forum General Tech Discussion
    Last Post: 03-11-2010, 10:36 PM
  2. Problems with a 97' GT
    By drumstom in forum General Tech Discussion
    Last Post: 12-11-2009, 11:00 PM
  3. Need Help - Having problems
    By dellfire in forum General Tech Discussion
    Last Post: 11-04-2009, 10:01 PM
  4. DIC problems
    By rookie in forum General Tech Discussion
    Last Post: 03-07-2009, 03:22 AM
  5. some problems
    By EmEaston24 in forum General Tech Discussion
    Last Post: 09-23-2008, 06:28 PM
