Thread: PCM and Pulley upgrade
Results 1 to 20 of 30
  1. #1 Re: PCM and Pulley upgrade
    Donating Users blowfishRus6's Avatar
    g.a.
    ha not you silly. im talking to the OP. if you can get it out the hole good mid 14's is doable.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: PCM and Pulley upgrade
    GT Level Member Whitehispanic's Avatar
    Westborough
    does it matter if i just get the pcm first and the intake rather than getting the pulley and all the other upgrades or does it have to be all at the same time??
  3. #3 Re: PCM and Pulley upgrade
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by Whitehispanic View Post
    You'll be fine getting just the PCM and intake. DO NOT mess with pulley sizes until AFTER you have a sufficient amount of exhaust mods, which you will be able to determine by scanning. Since our cars are getting older and KR is becoming more of a problem I would suggest getting header's before you start dropping pulley sizes.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  4. #4 Re: PCM and Pulley upgrade
    Westborough
    Quote Originally Posted by Smokin2000gtp View Post
    how will the pcm know when the other mods are on or do i have to get a new pcm?? Sorry i ask so many questions i just want to make sure before doing something i am not supposed to do LOL
  5. #5 Re: PCM and Pulley upgrade
    Jul 2008
    Dekalb, IL
    Aftermarket PCM's just have a generic tune, they aren't really mod specific. If you want a tune that is set up specifically for your car and the mods you have, then you're going to have to get a tuner. But to kinda answer your question if you get a pcm, you'll be fine with adding mods later, no need to change anything. Tuning it would be better, but for most cases it isn't really necessary.
  1. need upgrade help
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 01-28-2010, 11:33 AM
  2. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  3. First upgrade...
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-13-2008, 11:13 AM
