Thread: what plugs and gap.
Results 1 to 7 of 7
  1. #1 what plugs and gap.
    Jun 2012
    820a louisiana ave, saint cloud, FL, 34769, United States
    well going over my car that i got fixing all the issues i can find. here is a sort list of mods. what plugs should be in the car and what gap? cars on a 2.75 pullie about 17psi
    - Gen V Supercharger 17psi, Thrasher-Performance Modular Interchangeable Pulley System
    - 75mm North Star Throttle Body, 85mm LS6 Mass Air Conversion
    - 4 inch Air Intake
    - 42.5 lb Injectors
    - Alcohol Systems Methanol Injection System
    - DHP Computer
    - Pacesetter 1-3/4 Race Headers with 3 inch Downpipe, Dual 2.5 Tailpipes w/ Flowmaster 40 series Mufflers
    - ZZP Performance Full Stack Stage 2 Liquid to Air Intercooler with Stage 2 Heat Exchanger and Cooling Fan added
    - ZZP Performance 1.9 Modded Rockers
    - ZZP Performance Under-drive Water Pump Pulley
    - ZZP Performance Alternator Amp Booster
    - New ZZP 10.3 Wires
    Serious?
    Put a 3.2 on there.
    Plugs would be 103's gapped at 0.035 if you could run that much boost.
  3. #3 Re: what plugs and gap.
    Jun 2012
    it seems to run the boost fine from what i see. it knocks here and there around 60-80 mph like spots of 1-5. but it could be tune related. im throwing wideband on in the next couple days. i plan to go to maybe a 3.0? or 3.2? think that would work better for my setup ?
  4. #4 Re: what plugs and gap.
    May 2008
    staten island,NY
    i run NGK TR6 gapped at 35, never was crazy about autolite.
    Matt is right way too small of a pulley for your mods, bigger pulley with more timing will make more power
  5. #5 Re: what plugs and gap.
    Jun 2012
    lol from what i been seeing yea pulley is next on the list. im just trying to go threw this car and fix one thing at a time. just got oil to stop leaking, oil level sensor changed, intercooler pump changed, next is getting rid of msd coils, check and change plugs if i need to
  6. #6 Re: what plugs and gap.
    Jun 2012
    well i did more work . on 75% throttle it wont knock at all entire pull. full throttle it knocks higher rpms. so i just checked whats in the car. i got 103s but there gapped at .45 so i wonder if this could be my random misfire. im going to change them to .35 and just get new plugs while there out. and then i will change the msd coils to stock and see what happens. i measured the pulley to and seems to be a 3.0 but im about to make a new thread for that .
    Stop making new threads.
  1. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  2. What plugs should i get?
    By gtpeddie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2012, 10:25 AM
  3. Plugs
    By rbriggs665 in forum Shops and Community Heroes
    Last Post: 03-12-2012, 07:49 AM
  4. plugs?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-12-2009, 06:05 PM
  5. What plugs should i use?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2008, 02:00 PM
