Thread: Air fuel, O2 readings off, causing weird acceleration
Results 1 to 20 of 25
  1. #1 Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    For the first couple minutes of running it will accelerate nice and smooth. After the first couple minutes, it will accelerate with a very slight hesitation every second or so. My AFR doesn't seem too bad, stays around 14.6 to 15. I think the problem is visible in the O2 readings though. It will stay around 800-900ish then drop to under 100 for a fraction of a second, when I presume the hesitation is occurring. Also idle will jump in neutral if the car is warm. No codes.
    Thought it was the O2 sensor but replaced that to no avail. Ideas?
    Thanks
    Slowest 'Cooled Gen V ever
  2. #2 Re: Air fuel, O2 readings off, causing weird acceleration
    the o2 sensor is supposed to have pretty big cyclic swings like that.
  3. #3 Re: Air fuel, O2 readings off, causing weird acceleration
    Have you considered that your knock sensors aren't active until 160F? You may have knock a misfire etc etc.
  4. #4 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    Bio, good because its a new O2 sensor so I'm glad that's not the issue.
    Bill, I don't go over 2500 RPM's until I'm over 160*. Aeroforce says no misfires or KR at any point. The issue always occurs when the car is warm (over 160*).
  5. #5 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    Other things I can think of, when car is warm and in neutral and the idle is surging, Lift's are pegged at 16.4. I would think this is a vacation leak but wouldn't it surge when its cold too, not just when its warm?
  6. #6 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    Nothing?
  7. #7 Re: Air fuel, O2 readings off, causing weird acceleration
  8. #8 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    +16.4 LTFT is a vacuum leak. find it.
    Believe me I have. When I reset the fuel trims (unplug battery for about an hour) it won't settle in at 16.4 for at least a few minutes. Would that still be a vacation leak?
  9. #9 Re: Air fuel, O2 readings off, causing weird acceleration
    Quincy, Mass
    yes that with your other symptoms points to a vac leak
    No more GP 04 Impala SS Indy:
  10. #10 Re: Air fuel, O2 readings off, causing weird acceleration
  11. #11 Re: Air fuel, O2 readings off, causing weird acceleration
    Pennsylvania
    I wish I had a vacation leak.
  12. #12 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    Well I've sprayed TB cleaner around the base of the IC and SC, all the vacation lines on the SC, and the TB joints. What am I missing?
  13. #13 Re: Air fuel, O2 readings off, causing weird acceleration
    Pennsylvania
    You still have your MAF screen installed, right?
  14. #14 Re: Air fuel, O2 readings off, causing weird acceleration
    egr tube?
    If you have an intercooler, are you still running garleaks?
    O2 sensors oscillate because they're only accurate at finding lambda of one, thus they have to go above and below to attempt to stay close to the centre.
  15. #15 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    Quote Originally Posted by SlowNA06 View Post
    Yes sir.
  16. #16 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    egr tube?
    Haven't checked the EGR, will do.
    No more Garlocs, right stuff RTV now. I couldn't believe how horrible the Garlocs were when I took them off. Oil everywhere.
    My wondering about the O2 osculation was, could it be osculating enough to cause an RPM surge or slight hesitation when accelerating.
  17. #17 Re: Air fuel, O2 readings off, causing weird acceleration
    Slower is a sign of a weak O2.
    What are you using to capture these figures?
  18. #18 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    What do you mean by slower?
    Going off of my Aeroforce.
  19. #19 Re: Air fuel, O2 readings off, causing weird acceleration
    Vancouver, WA
    On the way to work today I had p1133 pop up. Looks like bad O2 but I just replaced. I cleared the code and drove for about 20 more minutes and it didn't come back. I recall having this happen on my previous O2 that I thought was bad but turned out not to be. Ideas?
  20. #20 Re: Air fuel, O2 readings off, causing weird acceleration
    Pennsylvania
    Touching wires?
  1. Fuel Pressure & Other Weird Issues
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 05:27 PM
  2. weird fuel pump problem
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-26-2011, 07:44 PM
  3. O2 readings
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 10:44 PM
  4. Weird sound on acceleration?
    By CSteen85 in forum General Tech Discussion
    Last Post: 05-01-2010, 10:20 PM
  5. weird missing on heavy acceleration
    By ricky861986 in forum Introductions/Noob Questions
    Last Post: 04-27-2009, 03:30 PM
