Thread: weird fuel pump problem
Results 1 to 5 of 5
  1. #1 weird fuel pump problem
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    saturday i replaced my fuel filter. started it up went about 20ft and stalled. next day took pump out (thank god for access panel) and then my buddy wanted to plug it in and turn the key on with it out of the tank.
    it sounded like it was pumping. so we put it back in the tank hooked it up and started the car and let it run a little. then it stalled. pump was no longer pumping
    so we pulled the line off at the fuel pump and turned the key on and it pumped. after we hooked the hoses back up it has ran ever since.
    another weird thing is when we started it up the tach stopped workingl. my buddy followed me home and it started working again.
    im thinking electrical problem. what do you guys think
  2. #2 Re: weird fuel pump problem
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    What year is the car, you may have a bad fuel pump resistor. This caused mine to stall out quite a bit a few years ago. Will it kind of star up and shut right back off almost immediately?
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  3. #3 Re: weird fuel pump problem
    Jul 2011
    Michigan
    before it started working again normally when i turned the key you could feel something kick on in the pump but wouldnt pump
  4. #4 Re: weird fuel pump problem
    PA
    It would help to know what year, make, model car you have. You just posted in the general tech section, so hard to tell.
    But off the cuff, I would guess the crank position sensor because of the issue with the tach.
    2001 GSE
  5. #5 Re: weird fuel pump problem
    Jul 2011
    Michigan
    its a 97 gp gt
  1. 97 gtp fuel pump problem
    By billysmth555 in forum General Tech Discussion
    Last Post: 03-16-2011, 04:31 PM
  2. Problem after taking out fuel pump.
    By GAFF in forum General Tech Discussion
    Last Post: 02-21-2011, 03:15 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. fuel pump ground problem?
    By roger41076 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 02:00 PM
  5. Fuel Pump Problem
    By ericrluoma in forum General Tech Discussion
    Last Post: 04-13-2009, 01:19 PM
