Thread: Premium fuel required!?
Results 1 to 20 of 46
  1. #1 Premium fuel required!?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I was washing my 01 GTP today and when I opened the gas cover, I noticed a sticker that says "PREMIUM UNLEADED FUEL ONLY"
    ...Im like ! Nooo! Premium is $4.50!
    I have been putting reg in there since the day I got the car. No problem that I can notice.
    So whats the deal with premium only? Is it harmfull to put regular in there? Please enlighten me about this whole premium only deal.
    Thanks!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Premium fuel required!?
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Without Premium fuel, your more than likely experiencing pre-detonation when your engine is under boost or under load. That is a bad thing and can cost you a new engine. You should only run regular unleaded if you have tuned your car to run on it. I for one, would never put anything but premium in my tank since it only cost $3 more a tank. It would take a lot of $3 savings to = a new or rebuilt engine.
    If your modded at all and have been running regular, I would be surprised that you haven't chipped a piston yet.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  3. #3 Re: Premium fuel required!?
    Bartlett, IL
    Quote Originally Posted by JJ91284 View Post
    Your right. I had no idea that the car needed premium. I was a little shocked by that. I will from now on run premium. Also the car is stock.
    Quick question about premium for my car.
    Will it improve gas mileage? I see people saying that get 23-26 mpg when no matter how granny I drive, I still am under 21mpg.
    How To: E-Brake Pwn
  4. #4 Re: Premium fuel required!?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Quote Originally Posted by Freebeer187 View Post
    I don't think so, but I could be wrong. Unless you have been running the 10% ethanol. If you have then you should see an increase in gas mileage. If I was you I would do a tune up on your car. Change things like fuel filter, air filter, plugs, wires, O2 sensor. That is if they haven't already.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  5. #5 Re: Premium fuel required!?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Not sure if you will notice a change in MPG
    Your PCM has a high octane spark table and a low octane spark table. When using regular gas it will use the low octane spark table to prevent knock. Many people have used regular gas on stock s/c V6's without issue. Since the low octane spark table has greatly reduced timing versus the High octane table you notice an increase in performance switching to premium.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Premium fuel required!?
    SE Level Member sUpErClEaNbLaCkMaChInE's Avatar
    STOCKTON, CA
    I just barely bought my car i got an 07 grand prix and my gas mileage sucks as well. the only tip i have is that u fill up at night or early in the morning when its not so hot because the heat expands the gas therefore ur not getting the amount ur paying for. also, see what kind of gas u use because arco is crap i only put chevron premium in mine and my mpg is 24 now compared to 19.5
  7. #7 Re: Premium fuel required!?
    New Salem, ND
    Quote Originally Posted by sUpErClEaNbLaCkMaChInE View Post
    Underground tanks should be the same temp all day I would assume.
  8. #8 Re: Premium fuel required!?
    Barksdale AFB, LA
    While I know that fuel does expand with temperature, the tanks are underground and well insulated. The sun's rays have no effect.
    Regardless of how hot it is outside or what time of day, the metal part of the handle is always pretty cool when I pump the gas.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Premium fuel required!?
    Bartlett, IL
    Quote Originally Posted by Andrew_99GTP View Post
    Just had a small tune up the other day. Replaced old PMK (something like that, i forgot the name) plugs with AC Declco plugs. Also cleaned the fuel injectors and intake manifold. Put a drop in K&N filter in about a month ago. Oil is good too. After the tune up, the car just runs great (it did before but now its even better). It gives a real smooth ride with a little pick up too.
    Quote Originally Posted by IndeedSS View Post
    I didnt know that about the low/high spark. I have about 2 gallons of reg in my tank. I have a long drive tmw (about 30 miles on the high way) so im hoping to burn up whatever I have before that trip and fill it up the premium.
    Thanks for all the help!
    How To: E-Brake Pwn
  10. #10 Re: Premium fuel required!?
    Schaumburg, IL
    I personally think the pcm still adds to much timing under the Bad Fuel SPark table. If I recall correctly, the pcm (97-03) adds around 8 degrees of timing under full load on the BFST. Under the 04+ grand prixs, the pcm pulls the timing to like 0 under full load under BFST. I uploaded an 05 comp g timing tables to my gtp and the cruise timing was increased from around 30 to 44 degrees of timing. While running on low octane fuel it drops the timing way more than my 97 bad spark table. The 04+ gtp's say you can run on regular fuel but your power will be reduced and that would be partially because the timing was pulled
  11. #11 Re: Premium fuel required!?
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    It is safe to say that when you run higher octane fuel, you will get worse gas mileage (unless you have a tune other than stock).
    Further, I feel ya on the bad gas mileage - my 97 GTP only gets about 21-23 MPG mixed city and hwy driving. It would be nice to get the 25-26 MPG like the other fellas on here.... but I'm working on that.
    Good Luck!
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  12. #12 Re: Premium fuel required!?
    New Salem, ND
    I am getting 29mpg with my regal now and running 89 octane with 10% ethanol. I hope I can squeeze some more out of it though.
  13. #13 Re: Premium fuel required!?
    STOCKTON, CA
    Quote Originally Posted by GreenNirvana101 View Post
    Good Luck!
    exactly how will u be working on that???? do you have any tips for increasing fuel economy cuz my gp sucks ass on gas.
    2007 GP GT 3.8 S/C.180 Tstat. 605 ALs. Drop in K&N. 45K HIDS.
    1984 CHEVY C-10
    1986 OLDS CUTLASS SUPREME
  14. #14 Re: Premium fuel required!?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i will say this-- i know of a daily driver stock 99 regal gs that has had a pretty steady diet of 87/89 octane most all of its life, and it's at 187K miles.
  15. #15 Re: Premium fuel required!?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    so your saving yoour self less then 4 buxs.
    Spend the 4 buxs and add what it needs. Its going to take 4-5 tanks to fully get the full octane back
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  16. #16 Re: Premium fuel required!?
    Bartlett, IL
    Quote Originally Posted by Toofastgs View Post
    Ive been putting premium in for about 3 tanks now. Nice performance increase
    How To: E-Brake Pwn
  17. #17 Re: Premium fuel required!?
    SE Level Member BlackGS's Avatar
    Central Jersey
    Depending on your driving style, you should see an increase in MPG by running premium, but probably not a ton. When running off the Low Octane table, you would have to give it a lot more throttle to get the same power, but since the higher octane burns less effective, it might even out.
    Running low octane and low timing is also going to increase EGT's which could lead to valve damage or cat overheating.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  18. #18 Re: Premium fuel required!?
    Bastard Reptile's Avatar
    Kansas City, MO
    Higher octane fuel does NOT burn less effective. Once ignited, it burns the same or faster than low octane fuel depending on the blend of gasoline used.
  19. #19 Re: Premium fuel required!?
    Central Jersey
    "Burns less effective" was the wrong term - that's not what I was implying, so sorry for any confusion. I should have explained:
    By running high octane, the higher timing table will increase IPW's depending on load. However, efficiency for power should be increased, so loads should be less than running low timing. Just depends on how you drive. I would also suspect that warm-up is slightly increased with higher octane, and fuel usage could suffer, but that is just a guess.
    Bottom line is, this engine was designed to run high octane to maximize burn efficiency under the factory timing settings that give the advertised HP. You will get best performance and mpg by running the recommended fuel and driving conservatively (if possible ).
  20. #20 Re: Premium fuel required!?
    May 2008
    McHenry IL
    i run premuim but the first fill up "about 3 weeks ago i accidently didnt read the manual or door sticker and put about 3/4 87 octane. oppps lol i added all premium 93 today.
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. At what point do I need to switch to premium
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2008, 11:26 AM
  3. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  4. Do you see huge benefits in premium/hi-test/whatever you wanna call it.
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2008, 08:11 PM
  5. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
