Thread: Premium fuel required!?
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 46
  1. #1 Re: Premium fuel required!?
    NJ
    one time the retarded gas attendant put reg in my gtx and it turned into a put put no lie....
  2. #2 Re: Premium fuel required!?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by eXceL(FAM) View Post
    i still think it's wierd that it's illegal to pump your own gas in NJ
  3. #3 Re: Premium fuel required!?
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by Toasty View Post
    seriously?
  4. #4 Re: Premium fuel required!?
    PA
    Quote Originally Posted by Reptile View Post
    seriously?
    Yeah, seriously. They have a law that only gas station attendants can pump gas. How ridiculous...
    2001 GSE
  5. #5 Re: Premium fuel required!?
    SE Level Member BlackGS's Avatar
    Central Jersey
    The really strange thing is that our gas prices are much lower than the neighboring states. So, we get cheap gas and we don't even have to get out of the car.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  6. #6 Re: Premium fuel required!?
    Kansas City, MO
    The fuel does expand once it heats up. You never notice this because of the evap system on the cars equalizes the pressure when it expands and contracts.
    On older cars, you'll hear the air rush in/out when you loosen the fuel cap.
  7. #7 Re: Premium fuel required!?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    My 95 Camaro would do that all the time when the tank was very low (under 1.5 gallons in tank)
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  8. #8 Re: Premium fuel required!?
    SE Level Member hodge's Avatar
    Jan 2009
    windsor,ont
    my o6 gt gets 21.5mpg on premium,and gas is more expensive in canada,which makes no sense since we export most of our oil to the U.S.the guy at the dealership told me that i would experience knocking if i didnt use premium.
  9. #9 Re: Premium fuel required!?
    Dec 2008
    Canada
    Quote Originally Posted by hodge View Post
    Yeah we get royally screwed at the pumps
  10. #10 Re: Premium fuel required!?
    SE Level Member keenan00gtp's Avatar
    Oct 2008
    Iowa
    what about 89 octane? they dont even sell premium in iowa, i dont think
    so far: borla catback exhaust, audio swap.
    waiting for warmer temps
  11. #11 Re: Premium fuel required!?
    SE Level Member sUpErClEaNbLaCkMaChInE's Avatar
    STOCKTON, CA
    Quote Originally Posted by keenan00gtp View Post
    dam that sucks ^
    2007 GP GT 3.8 S/C.180 Tstat. 605 ALs. Drop in K&N. 45K HIDS.
    1984 CHEVY C-10
    1986 OLDS CUTLASS SUPREME
  12. #12 Re: Premium fuel required!?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Sure they do, just about every station besides Casey's has Premium.
    2001 Buick Regal LS - Almost Stock
  13. #13 Re: Premium fuel required!?
    Nov 2008
    Searcy,Arkansas
    Well I always was told to run no less then 93 in a Forced induction car/truck. I did goof up and ran 87....Also ran 93 with 10% ethanol not thinking it would hurt...After about a month I threw a misfire code! My spark plugs was BAD! Im not saying that did do it! But I think it had ALOT to do with it. So I stopped using the one with ethanol. I usally can pull bout 350miles outta my tank on 93. And I go 75-80 on the freeway and I do get into the gas sometimes.
  14. #14 Re: Premium fuel required!?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    What is the issue with ethanol fuel? Is it only a problem in SC cars? We have few stations (only one that I know) that sell 100% gasoline and not mixed with 10% ethanol.
  15. #15 Re: Premium fuel required!?
    Barksdale AFB, LA
    Ethanol has less energy per a given volume, so the car might not run as hard on an ethanol mix. I know that E10 drains about 3MPG on the highway on my car as opposed to running 100% gasoline.
    2009 Subaru Impreza WRX STI
  16. #16 Re: Premium fuel required!?
    Out West
    Quote Originally Posted by Sabrewings View Post
    Actually, it leans out your fuel mixture a little, the car will correct for this in closed loop, but when running WOT you actually are running leaner than commanded.
    Whine with your Cheese?
  17. #17 Re: Premium fuel required!?
    May 2012
    Thunder Bay, Ontario, Canada
    So my 2007 Pontaic grand prix 3.8l supercharged should only run on premium? Ouch!
  18. #18 Re: Premium fuel required!?
    Ocala, FL
    Quote Originally Posted by 2007GrandPrixGT View Post
    Yes, as this 3 year old thread will teach you.
  19. #19 Re: Premium fuel required!?
    Really?
    The owners manual and even the fuel door tell you what grade of fuel to run.
    Closed.
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. At what point do I need to switch to premium
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2008, 11:26 AM
  3. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  4. Do you see huge benefits in premium/hi-test/whatever you wanna call it.
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2008, 08:11 PM
  5. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
