Thread: whats everyone using for an IC res?
Results 1 to 15 of 15
  1. #1 whats everyone using for an IC res?
    SE Level Member RoadMonster's Avatar
    Sep 2011
    Oshawa Ontario Canada
    Ok, so I was planning on using a Ford Lightening ic res but its just too big to fit anywhere under the hood. I'm looking for suggestions for a new tank now (something easily available) . Anyone?
    I may just walk the junkyard this weekend and see what I can find. I figure a coolant tank from a little 4 banger might work.
    3.5, togs and all the little stuff. Overkilled custom wideband O2 tune. GOING FAST WITH CLASS! MODS TO COME: GEN V, zzp stage 2 ic, 1.9 modded rockers, and built trans with 3.29 gears.
  2. #2 Re: whats everyone using for an IC res?
    I dont use one... :/
  3. #3 Re: whats everyone using for an IC res?
    Ohio
    res from a riviera or a cobra
  4. #4 Re: whats everyone using for an IC res?
    If you have a home made air intake the coolant bottle from a 97-98 gp would work.
  5. #5 Re: whats everyone using for an IC res?
    Sep 2011
    If I don't use a res how do you bleed the system?
    Also I know guys have used a cobra res with success but I doubt I'll find one in the junkyard.
    One more question, does the res tank need to be the highest point of the system, I'm 99.9% sure it does just want to confirm.
    I don't think a 98 w-body coolant res would be higher than the ic core, but I could be wrong...
    Thanks for your help!
  6. #6 Re: whats everyone using for an IC res?
    It helps.
    I used my car's stock res and added the flow detect kit as well. You can hear the fluid screaming through my overflow in the vid. It's kinda funny. Worked great for bleeding.
    You are correct, it's not a GP. But hopefully it gives you ideas.
  7. #7 Re: whats everyone using for an IC res?
    Texas
    It helps.
    Holy sheet there's a toilet under that hood.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: whats everyone using for an IC res?
    ^^^ on that though a bet a res really comes in handy on the really hot days as this was all when it wasn too hot out yet... but I has no numbers for hotter days...
  9. #9 Re: whats everyone using for an IC res?
    Never Never Land
    So is a resevoir needed or not?
  10. #10 Re: whats everyone using for an IC res?
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    all depends... go without one and test the in/out temps to see the difference...
    reason I say that is because when I (I as in like 5 other guys) originally put the IC on I didn have a res... was gonna just add one on sometime...
    Then... I did a temp test after some highway driving and then after some around town driving...
    With the highway, temps were like ~10* above ambient... around town was ~15-20* above ambient... this was on a ~65* day
    Another local with pretty much the same IC setup (think he had a different HE but still similar dimensions) had pretty much the same numbers with a res...
  11. #11 Re: whats everyone using for an IC res?
    I live here. TLSheff's Avatar
    Would be HIGHLY recommended, but anything is possible.
  12. #12 Re: whats everyone using for an IC res?
    Never Never Land
    Thanks TLS. How are you guys connecting the lines to the res? Just drilling holes and using the standard 3/4" tubing in and right back out? Or?
  13. #13 Re: whats everyone using for an IC res?
    Never Never Land
    Well say I didn't use one. How would I bleed/fill the sysem?
  14. #14 Re: whats everyone using for an IC res?
    I have a tube up by the fuse box that (I guess could technically be my "res") that I use... its at the highest point is all my lines...
  15. #15 Re: whats everyone using for an IC res?
    Never Never Land
    Anyone tried this? Intercooler Fill/ Reservoir kit
  1. whats up
    By ic1112 in forum Introductions/Noob Questions
    Last Post: 12-16-2010, 05:37 PM
  2. whats up?
    By KoNeKiD08 in forum Introductions/Noob Questions
    Last Post: 09-13-2010, 10:35 PM
  3. Whats better?
    By zildjian102 in forum General Tech Discussion
    Last Post: 08-20-2010, 12:32 AM
  4. Whats is this in my gp?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 11:16 PM
  5. whats up
    By qball98 in forum Introductions/Noob Questions
    Last Post: 05-07-2009, 11:27 PM
res
