Thread: not starting
Results 1 to 12 of 12
  1. #1 not starting
    Jun 2012
    south carolina
    new to the forum, not new to the grandprix.
    when i turn the key nothing happens and after about 5 to 10 sec. it starts, but only half the time.
    any help would be appreciated ty
  2. #2 Re: not starting
    What do you drive?
    When you say nothing happens.. does the engine crank? (cause..that's something happening and how can it start w/o cranking)
  3. #3 Re: not starting
    Topeka, KS
    Does it turn over and not fire? Does it just click? Does it click continuously then start?
    Sorry more info is needed.
  4. #4 Re: not starting
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Its probably a bad starter solenoid. Take it off and get it tested.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    I'm with him ^
    Or just find where the starter is and hit it with something and see if it starts, that's the actual mechanics test lol
  6. #6 Re: not starting
    Feb 2008
    Houston
    Quote Originally Posted by Kolton Lock View Post
    I'm with him ^
    LOL oh yeah I forgot about this!
  7. #7 Re: not starting
    Jun 2012
    south carolina
    and sorry about the Confusion i was not thinking when i typed this its not cranking does nothing. but i think it is the starter or the soleniod is bad, only thing that had me dumb founded is when i would run the battery down it would wait about 5 10 sec then pull all that it could and then start. then it started doing it with a good battery. ty for your help guys gals. oh yah im driven a 98 gtp prix with 3.2 pully and supporting mods. with 210,000 miles.
  8. #8 Re: not starting
    Jun 2012
    south carolina
    so the starter and the soloniod is not its. any suggestions? i held the key in start position for 20 sec and it started finally, but wont do it again
  9. #9 Re: not starting
    Feb 2008
    Houston
    Maybe your ignition is going bad. I would take a voltmeter positive to the purple wire on the starter and neg to ground and see if youre getting voltage while someone holds the key forward. Also make sure the ground strap going from the starter to the solenoid is tight.
  10. #10 Re: not starting
    have you tried to move the key back and fourth while in the start position? if you do that and it starts up , i would think its the ignition switch its self.
    you can also jump the solenoid on the starter to start the car up, if that works its not the starter. key has to be in the run position when jumping the starter.
  11. #11 Re: not starting
    Jun 2012
    south carolina
    $175 dollars later and starter is new boo hoo but still no run so ill try the volt meter and ty for the info. Yall are great.
    Mar 2012
    Minneapolis MN
    Did you get the starter done at a shop? Cause I know they are only like 80-100, at least when I did mine last September.
  1. starting
    By PontiacGT8 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2011, 12:43 PM
  2. starting to mod
    By LeThAlREMiX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 08:38 AM
  3. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  4. gtp not starting
    By mtz956 in forum General Tech Discussion
    Last Post: 12-04-2010, 07:46 PM
  5. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
