it might be your AC compressor if its the noise im thinking of. mine does it sometimes and sometimes it doesn't. when it makes the noise i turn on the AC and it goes away. if you take the belt of try and spin each pulley and check them you might find the problem that's why i did. then i sprayed lubricant on the AC compressor pulley.
