Thread: Fuel Pump
Results 1 to 20 of 23
  1. #1 Fuel Pump
    Never Never Land
    The fuel pump died on my 97 GTP. The resistor bypass did nothing. I can't even hear the pump priming.
    Sooo..I need a new one. Any recommendations? I'd like to get a drop where nothing needs to be modified.
  2. #2 Re: Fuel Pump
    did you bend the tab on the fuel pump relay yet?
  3. #3 Re: Fuel Pump
    Never Never Land
    I sure did.
  4. #4 Re: Fuel Pump
    have you swapped relays yet?
    Try banging on the tank with a hammer.
    but i guess it could be dead
  5. #5 Re: Fuel Pump
    Never Never Land
    Yup swapped the relay. I would assume the pump is dead with it not priming. However it never had any symptoms before. Started just fine everytime.
    Before it died it started up just fine. Drove it to the gas station. Put 10 bucks in. Started it, put it in drive...made it 2 feet and it died. Now I can't hear it prime or anything.
  6. #6 Re: Fuel Pump
    Never Never Land
    Hit the tank probably a dozen times with a mallet. Still nothin.
  7. #7 Re: Fuel Pump
    while cranking?
  8. #8 Re: Fuel Pump
    you need one of these, just the pump, dont buy the whole pump housing if you gas gauge works.
    NEW FUEL PUMP & STRAINER KIT GM VEHICLES VARIOUS GA1001 | eBay this should fit your car. beats 2 to 300 dont it?
  9. #9 Re: Fuel Pump
    Never Never Land
    No, not while cranking. I don't have 10 foot arms and i'm the only one home ATM....but it should at least start priming if it was going to work and it didn't....and the battery is damn near dead anyways.
    Egay pump? Hell naw. Lifetime warranty my ass. Some random no name brand....not going there. I'll replace it once with a quality product.
  10. #10 Re: Fuel Pump
    same price at your local parts store as well. but that thing is the pump. thats all you need to change.
  11. #11 Re: Fuel Pump
    Never Never Land
    Yes I know what the pump is. I need a sending unit too. My fuel gauge goes all over the place.
  12. #12 Re: Fuel Pump
    Jan 2012
    Philadelphia
    i need a sending unit to my gas gauge doesn't even work
  13. #13 Re: Fuel Pump
    oh your biting the bullet then.
  14. #14 Re: Fuel Pump
    Jan 2012
    Philadelphia
    who me? lol i ran out of gas a few times, i use my odometer and record my miles after each fill up with usually around .5 of a gallon less then what my DIC tells me im getting, and i used the "fuel used" on the DIC but that's not perfectly accurate. my range doesn't work either, my low fuel light is always on and the gas light on the HUD is always on to
  15. #15 Re: Fuel Pump
    both of you are ... i drove for just over a month with no cluster at all. no gas gauge blows, i did the same thing, but had to track my miles with my gps and also used it for a speedometer. i just gave myself a 10 miles to gallon rule and i never ran out of gas.
  16. #16 Re: Fuel Pump
    Jan 2012
    Philadelphia
    ehh, you get use to it lol
  17. #17 Re: Fuel Pump
    Never Never Land
    Replacing the sending unit is easy.
  18. #18 Re: Fuel Pump
    Jan 2012
    Philadelphia
    yea i dont think it'll be hard at all where do you think i should buy it from not looking to spend much at all
  19. #19 Re: Fuel Pump
    Portland Oregon
    I bet if you sweet talk Tengis he could put one together for you in a canister and ship it to you. He's got great deals on just pumps
  20. #20 Re: Fuel Pump
    Never Never Land
    Yea. But I've heard of 2 members gettin wrong parts or missing parts and Tengis didn't make it right. And Brandon said he was supposed to get his car tuned by Tengis and he never showed up or called
  1. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
