So I decided to put on the 3.1 pulley and tuned it a little. Here is a quick scan I did on the way to work. The car was at full temp as I had been driving it for about 45mins.
Device Time Engine RPM(rpm) Knock Retard(Deg.) Timing Advance(°) Throttle Position(Manifold)(%) H2OS Sensor(mV) Speed (OBD)(mph) 09:33.6 3916.5 0.791016 19 62.35294 - 70.83632 09:34.0 3916.5 0 19 100 911.4 70.83632 09:34.5 4750.75 0 19.5 100 911.4 74.56454 09:35.1 4947.25 0 19.5 100 924.42 78.29277 09:35.5 5160.5 0 19.5 100 924.42 82.021 09:36.1 5160.5 0 19.5 100 920.08 82.021 09:36.6 5285 0 19 100 933.1 85.12785 09:37.0 4164.25 0 18.5 100 933.1 87.61333 09:37.5 3963.75 0 18.5 100 924.42 89.47746
Here is another scan I did on the way home and the tune was the same. But notice the knock? Maybe the IC was heat soaked from driving on the highway for 1hr.
Any ideas why it would start to knock out of nowhere?
Device Time Engine RPM(rpm) Knock Retard(Deg.) Timing Advance(°) Throttle Position(Manifold)(%) H2OS Sensor(mV) Speed (OBD)(mph) O2 Volts Bank 1 sensor 1(V) 53:33.0 5061.5 0 19.5 100 941.78 43.49598 - 53:33.5 5460.5 0 19 100 941.78 47.84558 - 53:34.1 5875 0 18 100 946.12 50.95244 - 53:34.5 4245 0 18 100 941.78 50.95244 - 53:35.0 4245 1.142578 19 100 937.44 56.54478 - 53:35.5 4258.75 1.142578 17 100 937.44 60.89438 - 53:36.0 4372 1.582031 17 100 937.44 64.6226 - 53:36.5 4491.25 2.548828 17 100 933.1 68.97221 - 53:37.0 4666.5 3.955078 16 100 937.44 68.97221 - 53:37.5 4666.5 3.076172 16.5 100 933.1 72.70043 - 53:38.0 4838 3.076172 11.5 7.843137 620.62 76.42866 -
What do you guys think?
So what sort of AFR here?
10's? 11's? 12's?
my wideband 02 sensor just went out the other day so I ordered a new one from PLX I'm just waiting for it to come in. I will have it installed this weekend and do some more scans and see what its doing. I know the nb isnt very accurate to tune on but at the moment thats all i have. It seems like my fuel is all over the place. Here was another scan with the same tune but you can see it was richer. What would cause the fuel to be all over the place?
Device Time Engine RPM(rpm) Knock Retard(Deg.) Timing Advance(°) Throttle Position(Manifold)(%) H2OS Sensor(mV) Speed (OBD)(mph) 01:37.1 3125.75 0 16.5 32.54901886 733.460022 16.15565109 01:37.6 3125.75 0 18.5 49.41176605 954.7999878 21.12662125 01:38.0 3940 0 19 100 954.7999878 29.82581711 01:38.5 4537.75 0 19.5 100 954.7999878 36.66090012 01:39.0 5022.75 0 19.5 100 963.4799805 42.8746109 01:39.5 5022.75 0 20 100 963.4799805 42.8746109 01:40.0 5648 0 19 100 980.8400269 49.0883255 01:40.5 4049 0 19 100 980.8400269 53.43792343 01:41.1 4177.5 0 19 100 967.8200073 57.78752136 01:41.5 4300.5 0.3515625 19 100 963.4799805 62.13711929 01:42.0 4300.5 0.26367188 18.5 100 972.1599731 62.13711929 01:42.5 4000 0.26367188 34 7.84313726 759.5 65.24397278
