Thread: What to do? Block, crank and heads
Results 1 to 20 of 27
  1. #1 Re: What to do? Block, crank and heads
    Oklahoma
    While Ive never heard of any issue with the crank polished or otherwise, I'll look into that. I could see that being a problem if what little material removed was not taken into account for the bearings. The guy you are referring to is turbocharged406sbc. I have not seen him around these parts for a very long time and I was hoping to get some input from him as well.
  2. #2 Re: What to do? Block, crank and heads
    Wichita, KS
    Cranks can be resurfaced, polished, and ground.
    I only go as far as resurfacing/polishing where the bearings ride.
    When people grind the cranks down, so they can run a larger bearing, this is when you see problems and failures. The ONLY reason to grind a crank is if you had one spin and the crank surface is damaged beyond repair and you have to remove material and "start over" so to say.
    Not all shops can do this correctly, especially on one of our "mild steel" cranks. Takes the right tools, and knowhow to pull it off, and even then...you can do everything right, but the quality of the crank will bite you in the ass sometimes.
    I feel, in my opinion, if you have to grind on a crank for what ever reason on our cars, scrap it/**** can it, and get you a new/lower mileage crank to use and run that.
    ~F~
  1. i wanna build 300+ crank hp.
    By wildkyle90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 08:25 PM
  2. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  3. New guy on the block
    By Milestone in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:17 AM
  4. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
