Thread: What to do? Block, crank and heads
Results 1 to 20 of 27
  1. #1 Re: What to do? Block, crank and heads
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    I had diamond pistons never had a problem with them.
    Ran constant 2.6" pulley on em but i also watched A/F like a hawk3
    I had it all done to my block will i do it again. NO
    The end of my car ended up being a snapped crank.
    I had a bored .20 over, balanced crank, diamond pistons, double roller, Head work that matched Intense S3 hears and then some, over sized valves, IS3 cam, Clevite 77 Bearings, and total seal rings.
    IF your not gonna go all out, i would keep block stock, just replace bearings and seals, and TC tensioner.
    Before i went all out i had basics, 3.25, tog headers, 1.9 rockers later upgraded to a VS cam, intake, exhause and PCM. When i threw the vs cam in i dropped to a 3.0 dailey and a 2.9" fun at that time i had 2-3kr w/ 2.9"
    After i talked to many other people at the time stated our cranks are better left alone.
    at the time i was making damn near 400whp and just hit 500wtq.
    I also hear from some of the old top togs that had to pave the road for us, Chris green, ed, at the time stated stock blocks is what they ran doing 300+whp. Just watch kr // Af and it will hold out. I been out the game for so long i dont know to do anymore.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  2. #2 Re: What to do? Block, crank and heads
    Oklahoma
    Quote Originally Posted by Toofastgs View Post
    I planned on having the crank polished, but I wasnt so sure about balanced since Im not all that crazy about pulling the balance shaft and having to plug up the oiling there. Though, building up a block I would be more inclined to run an extremely mild cam, nothing crazy but I dont really care if I run a stock cam or a mild one.
    Most of my work is going to be focused on the heads and doing whatever I can to ensure the motor can take a bit of abuse. Admittedly, however, I am in uncharted territory here so while Im in this far I want to take care of any shortcomings and make sure that everything will hold up to some very spirited driving and track duty.
  1. i wanna build 300+ crank hp.
    By wildkyle90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 08:25 PM
  2. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  3. New guy on the block
    By Milestone in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:17 AM
  4. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
