Thread: Injector problem
Results 1 to 20 of 25
  1. #1 Re: Injector problem
    Of course you'd have a generac laying around.
  2. #2 Re: Injector problem
    SE Level Member TheYanz's Avatar
    Northwest Suburbs, IL
    Used one of those small 9v batteries to make the injectors click open. Dunno if that's enough voltage (consensus is apparently 12v) but it seemed to work very well. I was able to spray carb cleaner both ways thru them & let some soak on the inside for 5-10 mins in between on each 1 then finished it all off with compressed air to blow all the carb cleaner & hopefully mixed up crud out. Mpgs DEF greatly improved between the 2 sets of injectors: 1 ones from the engine swap that probably sat around a junk yard for some time vs. the original injectors set that came with the car. I was gauging about 22-23 city mpgs at night in some stop & go traffic in about 80* weather. Good stuff... LTFTs seems to have dropped & normalized as well. After the custom tune it was still >+5. Now it hovers around 0 with a little normal deviation each way. Perhaps 1 was clogged or not flowing right & the PCM was overcompensating w extra fuel on the others or something. Runs VERY well now. Thanks, guys.
    99' Black GTP/ '03 Motor. 3.4 MPS, 1.9 Rockers, Ported SC & TB, SD Headers, FastKatt Tune, 2.5" Exhaust, Dual Tips, 104's .055/ 180*, STBBs, 6000K HIDs + 6000K HID Fogs, Interior LEDs + Red LED Switches, 1,250w Infinity Sub, Red Calipers, NiCop Brake Lines.
  1. 04 gtp injector.
    By Toms04compg in forum General Tech Discussion
    Last Post: 04-18-2012, 11:34 AM
  2. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
