Quote Originally Posted by DnaProdigy View Post
If you go with a MPS i recommended putting locktite threadlocker on the bolts so their is no problem with vibration and them slipping out. Use the blue kind tho otherwise you could have problems removing the bolts in the future.
I would never recommend you use blue loctite on those bolts. I have never heard of an issue of them coming out, but if you are super concerned about it, I would use lock washers instead.
