Thread: Best way to scan for KR
Results 1 to 6 of 6
  1. #1 Best way to scan for KR
    May 2012
    Where winter never ends
    So a buddy and I got ScanXL and a High Speed USB OBDII scanner, along with the GM Package. When I go pick up my GTP from the dealer we are going to get some base KR maps, then go home and change to a 180* thermostat and put an intake on. We are planning on posting the information; however, what would you guys rather see? Data maps or Graphs or both. If so, what do you want it to be compared to? KR vs RPM vs Engine load? KR vs RPM vs Timing ADV? KR vs RPM vs Coolant temps?
    I can pull down most anything with this software.
  2. #2 Re: Best way to scan for KR
    180ยบ thermo wont help, lowering the coolant temp wont do anything, niether will an intake, its there for sound.
    You are going to have KR no matter what being that the car is stock.
    5-6* KR at the top of the shift is normal for a stock car.
  3. #3 Re: Best way to scan for KR
    Grand Island, Nebraska
    Um i didnt think it was quite that high. maybe 2-3.
  4. #4 Re: Best way to scan for KR
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I wouldn't mind seeing if KR drops a tiny bit with either an intake or 180* thermo. I doubt it will but still.
  5. #5 Re: Best way to scan for KR
    Florida
    ok here is what should be done after you get your base line.
    1) make sure it has 91 or higher fuel in it. never know if someone put regular in
    2) since your set on it put your intake and 180* tstat in.
    -minimal cost since you have planned for this.
    3) get a new set of plugs. if you have more then 5* of KR i'd say drop autolite 605's in and gap at like .055
    -$15 or less
    4) if it still has the Ubend in the exhaust have it removed. you can either buy a new 2.5" or 3" DP or take the car to a local shop and have a new pipe welded in with a O2 bung for the rear O2.
    -$30 at a local shop to $150 for a new down pipe shipped to you.
    this quick list would be what i would do if i were keeping it mostly stock. personally i would just get some Speed daddy headers and upgrade the exhaust all at one time vs spending $150+ on a down pipe.
  6. #6 Re: Best way to scan for KR
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    5-6* is normal at WOT doing a run up to 100mph thats what i peaked at bone stock
  1. my scan
    By 99prixgt in forum PCM Tuning
    Last Post: 09-05-2010, 03:11 PM
  2. pcm scan
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 10:32 PM
  3. take a look at this scan!
    By RICE KILLER in forum PCM Tuning
    Last Post: 07-15-2010, 08:23 PM
  4. kr scan
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2010, 08:17 AM
  5. My first scan... wth is going on?
    By PonchoDvr4Lfe in forum PCM Tuning
    Last Post: 10-22-2009, 09:55 AM
