Thread: Ticking sounds from 2001 GTP
Results 1 to 20 of 24
  1. #1 Ticking sounds from 2001 GTP
    SE Level Member BrentHamm's Avatar
    Nov 2011
    Manitoba Canada
    My son's 2001 GTP started making a ticking sound today. Gets faster with more rpms. When driving it seems to go away under 1,500 RPMs.
    Here is a link to a video with the sound.
    Fingers crossed that it's nothing to serious.
    http://youtu.be/DPSZjkjle80
  2. #2 Re: Ticking sounds from 2001 GTP
    Sounds internal to me.
    I hate to say it, but you may have spun a bearing.
    Pull the dip stick and see if there is like a glitter on it.
  3. #3 Re: Ticking sounds from 2001 GTP
    Nov 2011
    Manitoba Canada
    Hmm...i checked the oil earlier..and did not notice anything..but was not looking specifically for that either.
    But will look more closely in the morning. Thanks!
  4. #4 Re: Ticking sounds from 2001 GTP
    GT Level Member Toms04compg's Avatar
    Michigan
    If oil looks good... Grab a screw driver longer one or mech stethascope and touch the metal end on coupler head ect. It sound kind of like my flex plate did so crawl under by oil pan to the driver side of it and put your ear near that plastic cover it may sound from there. But if oil is sparkly that calls for pulling head off. Im actually fixing flex plate at the moment. Good luck
  5. #5 Re: Ticking sounds from 2001 GTP
    St. Louis
    Actually if the oil is sparkly then you get to install a new short block as a bearing (or more) is toast. Pulling the head won't help you here, unless it's to put it on a used shortblock.
    OP- Wipe the oil from the stick onto a WHITE towel and check it for junk. Sometimes the metal background of it being on the dipstick and make it appear differently. Same goes for trans fluid.
    And turn off the A/C on the next video so it doesn't mask some other sound. My .02- sounds like a rod knock starting.
  6. #6 Re: Ticking sounds from 2001 GTP
    i also heard the a/c turn off and on, does it make that noise when the a/c is off? could be the compressor clutch is bad, or the dreaded spun bearing.
  7. #7 Re: Ticking sounds from 2001 GTP
    Mercer, Pa
    Ticking can also be an exhaust leak such as cracked downpipe, bad gasket, cracked manifold or EGR tube. I chased a tick for awhile that was the EGR tube gasket. With an exhaust leak you can typically find the general area it is coming from such as front of the engine, rear passanger or front passanger.
    How many miles on the motor?
  8. #8 Re: Ticking sounds from 2001 GTP
    Nov 2011
    Manitoba Canada
    So..removed the the belts, no difference. Checked oil again, looks ok. Also tried it with/without air on, no difference.
    Have not tried some of the other things mentioned here but will.
    Thanks for all the tips. Still hope it's nothing to serious. (The rusted out rocker panals costed alot to fix...would hate to spend more)
  9. #9 Re: Ticking sounds from 2001 GTP
    Nov 2011
    Manitoba Canada
    Father in-law and son pulled the motor out today. Nothing funny in the pan. So far they have not found the source. Maybe did not need to pull the motor out...
  10. #10 Re: Ticking sounds from 2001 GTP
    check the flywheel over real good they like to crack, and you kinda need to pull the engine or trans, or at least separate them so you can get in there.
  11. #11 Re: Ticking sounds from 2001 GTP
    Apr 2012
    Chicago
    If the ticking is still there with the engine out, then you know its just a loud watch :-) Seriously, if you took the time to pull the entire engine, you may as well send out to a competent machine shop to check the crank and replace the bearings. Unfortunately I also recently spun a bearing. Started out as a simple tick.
  12. #12 Re: Ticking sounds from 2001 GTP
    St. Louis
    If the lower end is bad, you'll save more in the end by just getting a low mile longblock and swapping your accesories onto it as the machine shop has to do more than just stuff new bearings in the bottom end on these motors (align bore, etc..) Its just not worth it to most people. If you get lucky and score a complete engine then you have spare parts from your old one to keep onhand and use when something breaks. Then you don't have to go out and buy it.
    Quincy, Mass
    Well if just spun a rod bearing then replace the all the rod bearings. As long as no damage was done youll be fine.
    No more GP 04 Impala SS Indy:
  14. #14 Re: Ticking sounds from 2001 GTP
    St. Louis
    You cannot "just replace the rod bearings" on these motors w/o doing some machine work to be sure everything is straight otherwise the "rebuilt" bottom end will come apart shortly. And if a bearing spun the crank has to come out to be checked for damage to the journals which involves taking all the rod caps off anyway. The rod bolts are TTY and not reuseable so you have to buy new ones. So with the cost of replacement rod and main bearings, rod bolts, machine work to align bore the block, machine shop labor to reassemble everything vs. just getting a used short or longblock its really not worth the effort/money, unless you are really dead set on having the matching engine that came w/ the car.
  15. #15 Re: Ticking sounds from 2001 GTP
    Quincy, Mass
    i didnt spin a bearing but did replace to rod bearings without machining anything, and i know your not supposed to but reused to rod bolts and had no issues. i busted 3 pistons but that was unrelated.
    check out car-part.com for engines at junkyards near you.
  16. #16 Re: Ticking sounds from 2001 GTP
    Nov 2011
    Manitoba Canada
    Arggh. Piston is burnt, blue, sleeve is scorched. Not good at all. Not sure what to do now. This car has been a disaster for us. First the rusted out rockers..that we just fixed..and now this..like just a few tanks of gas later.
  17. #17 Re: Ticking sounds from 2001 GTP
    sorry to hear, start engine shopping.
  18. #18 Re: Ticking sounds from 2001 GTP
    Nov 2011
    Manitoba Canada
    Not sure what to do. What engines could be dropped in? I assume if i find a non supdercharged 3.8 it would work?
  19. #19 Re: Ticking sounds from 2001 GTP
    Nope.
    Dont buy a NA motor, you cant do that unless you know how to tune for the high compression motor. And alot of other thing.
    Start checking junkyards and carpart.com and craigslist for L67/L32 motors.
  20. #20 Re: Ticking sounds from 2001 GTP
    Nov 2011
    Manitoba Canada
    Well..bought a donor 2001 GTP with less miles than this one had. Was t-boned, so motor should be good. Going in later this week if all goes well.
  1. More Sounds...
    By Remnant King in forum General Tech Discussion
    Last Post: 02-17-2012, 01:10 PM
  2. 2001 GTP SE Front Fender same as 2001 GT
    By BrentHamm in forum Visual/Body Modifications
    Last Post: 12-19-2011, 05:22 PM
  3. still ticking
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-28-2011, 04:46 PM
  4. ticking ?
    By gtcoup in forum General Tech Discussion
    Last Post: 02-20-2011, 07:41 PM
  5. GT sounds like a gtp?
    By betsgtp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2010, 09:20 PM
