Ok so i cant get this thing to work. I spliced the colored power wire into the cigarette lighter in the cabin, Im pretty sure thats getting power because it sparked when it touched the fuel rail and it also blew a fuse (which i replaced) I have the white and blue ground wires twisted together and grounded to the LIM (Is it supposed to be like that, or should they each be grounded separately?) Then I had the yellow analog 2 wire connected to the middle brown wire into the EGR and my scanner showed 7.4 afr when it was running. I also tried attaching the gauge to the yellow wire and it just blinked 7.4 also. The black calibration wire has power too since it will light up the LED. In the scanner I have the custom PID setup as PID.2811/(5/15.04)+7.35 so since its reading around 7.4 I assume this means the analog out is 0v. Oh and I know the red switched power works also because I hooked the gauge up to it and it lit up. Im kind of guessing my unit or sensor is bad, which sucks. Am I doing something obviously wrong?
