Thread: Help with LC-1 Wideband wiring
Results 1 to 15 of 15
  1. #1 Re: Help with LC-1 Wideband wiring
    Grand Island, Nebraska
    Bill:
    I was trying to wire it though the EGR. I figured out now that the middle wire (brown) is not the right one, but it doesnt work with the gauge either.
    Im using a DB digital Air/Fuel gauge from innovate motorsports.
    Well i was using the middle wire from the egr but i feel like that isnt right anymore, I need to get the gauge to show right first because then Ill know the sensor/controller is working
    I left the settings original
    I bought it used from Explicit Spade
    The manual says this about the controller"
    red wire to 12v switched power - I have it spliced into the cigarette lighter in the cabin, I know this has power.
    "blue and white wires should be grounded to the same ground source. Optimally, these will be soldered to the same lug, and connected to a single point. when this isnt possible, connect each one to a separate lug, and attach in close proximity. Multiple lugs on the same bolt is not optimal, and can result in unwanted signal noise." I have these twisted together and crimped into the same lug (just crimping everything for now until i get it working)
    brown is analog out 2 and conects to the gauge/egr wire.
    black is the calibration wire and this does light up the LED when It has power.
    If anyone knows for sure which EGR wire to tap into I would love to know.
    So basically my problem is when i hook the gauge up it just says 7.4 which is 0 volts in the original setting.
  2. #2 Re: Help with LC-1 Wideband wiring
    Well I got the gauge to read so thats good! Ill still need that info on the egr though...
  1. Wiring Wideband Gauge
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2010, 02:05 PM
  2. Wideband
    By TurboGTP in forum Turbo
    Last Post: 12-17-2009, 11:36 PM
