Thread: Aliminum Oil pan Sawp on a L67
Results 1 to 2 of 2
  1. #1 Aliminum Oil pan Sawp on a L67
    Banned
    Sioux Falls, SD
    Im going to be putting a L67 Block in my 2007 GP. My question is on the L67 the metal oil pan has a windge tray that is part of the oil pan gasket. While on the other hand the Aluminum oil pan has the metal windge tray in the bottom of the pan and use RTV for the gasket. What do i do for the swap? Thanks for the help!! and Froman Keep ur b.s out of here!!
  2. #2 Re: Aliminum Oil pan Sawp on a L67
    Not sure, never swapped them.
    You can use a L67 pan gasket and L67 oil pan if you want...you told me it was complete...so just get a new L67 pan gasket.
    If all it takes is RTV, then put the L32 pan on it, with the L32 mount.
