Thread: Coolant temp sensor question
Results 1 to 5 of 5
  1. #1 Coolant temp sensor question
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    is the coolant temp sensor threads supposed to be showing at all? sensor does not want to screw all the way in. is the nut flush with the lower intake manifold?
    my temp gauge was reading about 210 today when i have a 180 t-stat, thinking underhood temps may be throwing off reading.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: Coolant temp sensor question
    Apr 2009
    Fort Worth TX
    It's an NPT (tapered) thread. If you get 3 or 4 threads in your OK. Make sure the manufacturer has a sealant on the threads. If not, use some Teflon tape or plumbers sealant.
  3. #3 Re: Coolant temp sensor question
    St. Louis
    Yes, it's ok to show some thread. Mine is like that as well. And 210 is well within the limit on temps. Unless you're tuned for that 180* stat then it's not doing a lot as the fans are still programmed to come on around 210-220 or so.
  4. #4 Re: Coolant temp sensor question
    Mar 2012
    Dallas
    i think my fans are not running as fast as they should be.
    im used to fans being pretty loud and blowing massive amounts of air.
    my fans just seem to be running on low speed it seems
  5. #5 Re: Coolant temp sensor question
    Quincy, Mass
    the fans have a high and low setting based on how hot the coolant gets. if you arent tuned for the 180 tstat then it wont turn on any sooner. with the 180 it will take a little longer to get up to the 226 or something like that for the high fans to come on.
    No more GP 04 Impala SS Indy:
  1. do i have a clogged injector or a bad coolant temp sensor
    By athalflife3 in forum General Tech Discussion
    Last Post: 07-09-2013, 02:14 AM
  2. Replaced coolant temp sensor and....
    By NerdPower in forum General Grand Prix Discussion
    Last Post: 04-23-2012, 04:38 PM
  3. Where is my Coolant Temp Sensor Wire!! Posted Vid
    By Hixc in forum General Tech Discussion
    Last Post: 08-15-2011, 08:39 AM
  4. Where is the coolant temp sensor located?
    By usetaboost in forum General Tech Discussion
    Last Post: 11-26-2010, 06:34 PM
  5. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
