Thread: What do I need to Cam?
Results 1 to 9 of 9
  1. #1 What do I need to Cam?
    Jan 2012
    N/A
    I have been thinking about throwing a cam in my 04 gtp
    Mods are: zzp short stack intercooler, 1.9 rockers, 3.3 supercharger pully, pacesetter headers, no cat, flowmasters. Tuned
    What am I looking at to throw something like an xp cam in? :-)
    Sent from my LS670 using Tapatalk 2
  2. #2 Re: What do I need to Cam?
    Jan 1970
    Maquoketa, Iowa
    Stock rockers
    105# ~ valve springs
    valve seals
    rocker bolts
    gasket kit, entire engine gasket kit may be cheaper than cover, lim, etc.
    new stock timing chain and dampener
    balancer puller rent or buy and do a search for the correct bolts to be used on the 3800s
    valve spring compressor tool rent or buy
    assembly lube
    coolant elbows
    coolant
    oil
    tools.
    More info-
    ZZPerformance - Cam Install Kit #ZZ-CAMIP
    One of the most often mistakes or overlooks is the break in oil. when installing all this crap water gets into areas that eventually end up in the oil pan, the best thing to prevent a spun bearing is to change the oil after the first startup, then again after a few miles. You may want to change it more than that. Use cheap oil if you want on the first couple changes.
  3. #3 Re: What do I need to Cam?
    Quincy, Mass
    yup id say that about does it.
    heres a good how to
    Eric Buono's Cam Install
    per those instructions, dont use dexcool, and you dont need new cam or balancer(crank) bolts.
    No more GP 04 Impala SS Indy:
  4. #4 Re: What do I need to Cam?
    Pennsylvania
  5. #5 Re: What do I need to Cam?
    GTX Level Member blackflag's Avatar
    Virginia
    off topic but how long have you had that ssic? and do you wish you had bought the full size?
  6. #6 Re: What do I need to Cam?
    Quote Originally Posted by FoSHO99 View Post
    Drain coolant before removing even the TB/UIM/Blower.
  7. #7 Re: What do I need to Cam?
    Quincy, Mass
    remove the front knock sensor to get most of the coolant out of the block.
  8. #8 Re: What do I need to Cam?
    Jan 1970
    Maquoketa, Iowa
    It just doesn't "disappear" completely after you drain something, there is always some left.
    Quincy, Mass
    Yup and it helps if you pull the knock sensor and then rock the motor forward a few times
cam
