Thread: security preventing start?
Results 1 to 13 of 13
  1. #1 security preventing start?
    Mar 2012
    michigan
    my 98 regal is haviong start issues and its not the starter it will fire up 5 - 10 times in a row then will hav no crank when turn key if i leave key in run pos for 5 min it will fire right up any ideas how to fix o ps the black peice on ignition that reads the vat chip is broke off i leave key in ignition to keep it in place has 2 wires still attatched is ther a way to by pass this sec chip reader?
  2. #2 Re: security preventing start?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    its not a "chip" its a resistor an electric current goes through it and if its not the right current out the other side the PCM tells the car not to start
    it was GMs moronic attempt to stop someone from jamming a screw driver in your ignition and driving away
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: security preventing start?
    Car should crank with or without seeing the right resistance. I think you should consider soldering the right value resistor in lower down and disconnecting the vats from the ign switch since it appears to be broken. Then determine if your battery cables are loose/corroded etc. Something else appears to be happening.
  4. #4 Re: security preventing start?
    Oct 2011
    Michigan
    Your right bill I was just telling him there's no "chip" in his car
  5. #5 Re: security preventing start?
    Mar 2012
    michigan
    ther is a chi in mine we havbe talked ab it before i got the right key i had issuses w ignition and lady giving me wrong key when purchased car dealership cut me a reg steel key witch turned the ignition but no crank when got key with chip in it it fired up but had the 5 to 10 time start then nothing probloms along withj lower intake leak
    how do i tell what resistor to put in does it have to be soldered in or can i twist wires and tape it before just to check if car starts up every time
  6. #6 Re: security preventing start?
    Touch each side of the metal in the plastic with one lead from an ohm meter. It'll give you a reading. That's the resistance.
  7. #7 Re: security preventing start?
    Mar 2012
    michigan
    ok thats easy enuff whaere do i put the resistor just it the wires that r hooked to the ignition peice that is broke sorry to sound so stupid jus dont wana put it in wrong and dont resistors have a one way circuit?
  8. #8 Re: security preventing start?
    yes, locate the wires further down teh column, unhook them from teh ign switch and solder.
  9. #9 Re: security preventing start?
    cant the dealer tell you what ohm the key is by just calling them or stopping by with the VIN in hand to ask them?
  10. #10 Re: security preventing start?
    Quincy, Mass
    hold on so you got the right key so it starts and then cuts out. did you do a full security learn with the new chipped key so your pcm knows its the right key?
    No more GP 04 Impala SS Indy:
  11. #11 Re: security preventing start?
    he has a plain blank key the dealer cut, he got the wrong key when he got the car, so the key that works is un chipped, that would let it run and then die.
    he needs to know the ohm's of what the key should be. so he can get the right key, theres like 10 different key chip ohm's
  12. #12 Re: security preventing start?
    Grand Rapids, MI
  13. #13 Re: security preventing start?
    see list of different vat ohm's
    VATS Chip Number Ohms
    1 0.402
    2 0.523
    3 0.681
    4 0.887
    5 1.130
    6 1.470
    7 1.870
    8 2.370
    9 3.010
    10 3.740
    11 4.750
    12 6.040
    13 7.500
    14 9.530
    15 11.80
  1. Car security system went into lock down cant start car help!
    By guimond47 in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2011, 06:50 AM
  2. PLEASE HELP! 02 GTP No Crank No Start with security light
    By CandyBlueta in forum General Tech Discussion
    Last Post: 02-08-2011, 12:43 PM
  3. Auto start or security system
    By sasquatch094 in forum General Tech Discussion
    Last Post: 12-09-2009, 10:16 AM
  4. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  5. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
