Thread: PLEASE HELP! 02 GTP No Crank No Start with security light
Results 1 to 11 of 11
Threaded View
  1. #1 PLEASE HELP! 02 GTP No Crank No Start with security light
    SE Level Member CandyBlueta's Avatar
    Nov 2010
    Texas
    Ok here is the vehicle info...
    2002 GTP
    Bone Stock
    2 door
    148k
    Redfire metallic
    Problem info....
    I try and start the car and sometimes it will fire up first try, other times it will take between 20-200 turns of the key before it will finally crank and fire. When it doesnt start, there is no cranking or anything. just the click of the starter relay. It has power to all the normal interior things and what not. Also the keys go in and come out of the ignition tumbler just fine. no hang-ups there
    The security light was on before this started happening and still is on. It doesnt flash, just stays on. It has the Pass-Key 3 system
    There are 2 codes for the security light stored. They are:
    P1629C- Theft deterrent Fuel Enable Signal Lost
    and
    B2955- Key Code Input is Short to Battery
    The problem has gotten progressively worse in about a week.
    What ive done...
    Ive done as much research as i possibly can.. i have checked all wiring in the steering column and found no frays burns or previous hack-jobs. Ive also replaced the starter and the battery. The passkey reset procedure doesnt work because the security light never "shuts-off" after 10 minutes. i even tried following the process to no avail...
    New starter
    New Battery
    Wiring checked
    I Dont get it... Help?
  1. Security light
    By Soviet in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2010, 06:45 PM
  2. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  3. Auto start or security system
    By sasquatch094 in forum General Tech Discussion
    Last Post: 12-09-2009, 10:16 AM
  4. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
  5. HELP-car wont start/crank
    By fst in forum General Tech Discussion
    Last Post: 12-25-2008, 06:06 PM
