Thread: could i run a 3.4 pulley with these mods?
Results 1 to 20 of 36
  1. #1 could i run a 3.4 pulley with these mods?
    Aug 2008
    Long Island, New York
    hey guys, all my mods are listed below. If i also got a 180 tstat and autolite 104 plugs would I be able to run a 3.4 inch pulley on my car without knock? I have a scanner in my auto tech class at school so i could scan for it.
  2. #2 Re: could i run a 3.4 pulley with these mods?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Without Kr, probably no but it shouldn't be that much. You may need ported exhaust manifolds/ headers. I would say its safe with the mods you have to install it and then scan for Kr and go from there.
    2006 Grand Prix GXP
  3. #3 Re: could i run a 3.4 pulley with these mods?
    id get a 3.5 at most. get something else to help with air movement (rockers, powerlog, headers, cam, etc.) and you should be good to go down lower.
  4. #4 Re: could i run a 3.4 pulley with these mods?
    Banned
    Wichita Falls, Texas
    I'd say your good to go.
  5. #5 Re: could i run a 3.4 pulley with these mods?
    Jan 1970
    Maquoketa, Iowa
    A little KR but if your asking you sound like you want to do the right thing for your car, a 3.5 will make you happy too... Scan it on a day that has the least favorable conditions, (hot, go up hills, etc.) and thats when you should see the most KR, if its a lot then either drive accordingly or switch pulleys.
    I'd invest in a MPS though if you plan on switching back to something like a 3.5 or get into heavier mods...
  6. #6 Re: could i run a 3.4 pulley with these mods?
    SE Level Member GTPsex's Avatar
    Cedar Falls, Iowa
    how much would a catback exhaust help, and is the u ben before or after the cat...? i plan on getting a magnaflow catback and im not sure if i'd also need to get a u bend delete or not.
  7. #7 Re: could i run a 3.4 pulley with these mods?
    Jul 2008
    New York
    Quote Originally Posted by GTPsex View Post
    It is after the cat. It helps a bit if you are looking for a 3.4 but not much. beleive it or not the stock cat and mufflers are quite free flowing, some say moreso then aftermarket so in essence all you are really doing is deleting the ubend and res [performance speaking].
    Cheepest way to run a 3.4 safely
    1) Cai = Less then $60 if you make it yourself
    2) PCM = $100
    3) Plog = $120
    4) Colder Plugs [104's] =$10
    5) 180* T-stat = $10
    6)3" DP = $140 bolt in offroad [no cat]. Get a used one MUCH cheaper, with cat for emissions.
    Total = $380 is a cheep price to pay for a 3.4.
    It can be done with less but this is a good estimate. Access to a scanner is a good thing to have also to see you Kr. Also if you plan on modding further get headers instead of the DP and plog. And a tuner instead of the PCM.
    2006 Grand Prix GXP
  8. #8 Re: could i run a 3.4 pulley with these mods?
    Banned
    oswego
    Quote Originally Posted by DnaProdigy View Post
    2) PCM = $100
    3) Plog = $120
    ok, now i must rant. I preach and preach about pulley's because i don't understand why everyone thinks putting on a smaller pulley is going to unleash a huge amount of hp.
    Do any of you understand WHY we put smaller pulley's on our cars? With some of the answers i've seen here i'm assuming you don't. When you put mods such as... intake, headers, rockers, plugs, on our cars it makes our engine's more efficient. Moving air through the motor more efficiently while the blower is still spinning at stock speed will cause boost loss. The exact same amount of air is still getting rammed through the motor but now it's being done so easily there is an on average loss of about 3-5psi depending on numerous things. Then we put on the appropriate pulley to spin the blower fast enough to get about stock boost maybe a little more. If you spin the blower to fast you'll start boost stacking and without an i/c you're asking for trouble.
    Why? Well the m90 isn't very efficient since it pressurizes the intake charge in the intake manifold and puts out A LOT of heat. Running a pulley to small for the supporting mods is going to cause the car to boost stack, and that causes a lot of heat, which in turns leads to detonation. I know all of you guys get all your information from all the vendors and that's what they say is needed to run a 3.4 pulley. Yea, they are right, that's the minimal needed to run a 3.4 pulley. Are you going to get kr? Yep. Another thing that ticks me off is people that think its ok to have 1-4* of kr... why would that be ok? Because everyone else has it? Everyone else has it because everyone else is running a 3.4 pulley with intake, dp, plog, plugs, and a pcm. I guarantee 8-10 cars running a 3.4 pulley with those mods gets kr, which does nothing but slow the car down. Timing in these cars is everything, hence why everyone with comparable mods that i have is running mid 13's and slower.
    Another reason why having your own tuner is a must, so you can tune YOUR car, and not let someone else guess what you need. mail order pcms are a waste of money imo. I'd rather save the 400 more dollars and do that **** myself. I'm acquiring another gtp soon and it's going to remain completely stock and i'm going to prove that i can take a stock gtp further than most of the 3.4 pulley guys have taken their setups. If you are running a correct 3.4 pulley setup you'll be mid 13's all day long, IF CORRECTLY DONE. I ran a 13.2@105 on a 3.4 pulley correctly tuned with absolutely no kr on 85* day. I use myself as an example because it seems like i'm the only one that understands what pulley's are for.... Boost doesn't make power without an i/c!!!
    FUEL>SPARK>BOOST in that order. First you get your fuel right, then you run the correct amount of timing, all with no kr, then and only then to do you run a smaller pulley.
    So to answer this question, there is no way that anyone can tell you what size pulley you can run. The only way to know is to scan your car and find out for yourself. I'll be willing to bet you have kr right now at the end of a 3rd gear pull on said mods and a stock pulley.
    Take it as it is, but i'm sick and tired of seeing 3.4 cars running high 13's and still trapping in the double digits. Those same cars would probably be faster on a stock pulley and when i acquire another gtp soon i will prove a stock one correctly tuned is faster than the vendors "safe" 3.4 setups. Sorry again for the rant.
  9. #9 Re: could i run a 3.4 pulley with these mods?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by 2000GTP View Post
    Well have you scanned your car yet?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  10. #10 Re: could i run a 3.4 pulley with these mods?
    Aug 2008
    Quote Originally Posted by Smokin2000gtp View Post
    no not yet, it takes a while for my teacher to get around to these things. And it might be hard to get him to let me go and drive around with the scanner during school.
  11. #11 Re: could i run a 3.4 pulley with these mods?
    Jul 2008
    New York
    As i already said, a scanner is a good thing to have to check for Kr, maybe more emphasis on the good. I have one so i guess i under emphasize the importance.
    I agree 100% with what you are saying. But do you realistically, think that people asking "can i run a 3.4 with my mods and no Kr" and "is the u-bend before or after the cat" are going to spend $400+ [$600 for a HP] on a tuner just to see results after they learn how to use it flawlessly? [No offense to said posters, ya gotta learn sometime]. Learning a tuner, correctly, takes more time then people care to spend, the appeal of instant gratification is too great.
    People want cheep easy mods for their car. Parts less then $100 that they have to remove/replace a few bolts to put on. You can tell people on here till you are blue in the face to buy a tuner and learn how to use it but they rarely will. Dropping pulleys sounds too appealing to reason with for some. Best you can do is list sporting mods to combat the inevitable Kr that will come with a 3.4. As i said in my first post , no way hes running 3.4 with his mods and no kr.
    2006 Grand Prix GXP
  12. #12 Re: could i run a 3.4 pulley with these mods?
    Banned
    oswego
    We i did quote you, which wasn't me attacking you (sorry if it seemed that way) but I just can't stand people that think pulley's make hp. The stuff you listed is just not enough. The vendors imo are wrong, i don't care how long they've been in the game their "safe" setups aren't safe at all. 90% of people that follow their stupid guidelines have at least one post each asking about how to get rid of their kr.
    Minimal you need, intake, headers, rockers/cam, to run a 3.4 pulley efficiently. If those were the supporting mods and that car was running a 3.4 pulley the mail order tune could be way more aggressive and actually make a difference. But no the vendors refuse to change their list of "safe supporting mods" because they keep assuming that people following this stuff know what they're doing. IMO they just do that so you come back and buy more **** you don't need (i.e. headers after ordering a plog and dp because they're better, or a 3.6 pulley because the 3.4 you just bought is to small) to replace the stuff you already bought.
    It's bullcrap, too many people are mislead to this and after they purchase what they think is enough to run a 3.4 pulley setup they find out now they need even more stuff to keep their car free of engine damaging kr. I just don't get it, i see it over and over and over and nobody does anything about it. I'm only 1 person, there's only so much i can do to help prevent this ya know? I also hate the tards that say its ok.... AHH!! It's not ok, if you don't have a correct answer to give someone DON'T GIVE IT. This guy is asking because he doesn't know, then you idiots tell him it's ok so he assumes its ok and does it. Sure enough he'll post up sooner or later wondering why his car is so slow. It's because of you morons, shut up if you don't know what you're talking about. If you think you know what you're talking about then you would have told him that wouldn't work instead of "sounds ok to me" yea i'm talking to you people...
  13. #13 Re: could i run a 3.4 pulley with these mods?
    Aug 2008
    I would love to buy a tuner and learn how to use it but i don't have the money and i need my car to drive every day. If i messed something up then i wouldn't have a car to drive.
  14. #14 Re: could i run a 3.4 pulley with these mods?
    im in the same boat. i refuse to learn how to tune because its too time consuming for me.
  15. #15 Re: could i run a 3.4 pulley with these mods?
    Donating Users blowfishRus6's Avatar
    g.a.
    if your really serious about your car, have the time and patience, want to farther mod your car down the road and want to make your car faster than others with the same mods and just make sure your cars runs to its best, get a tuner.
    majority of the off the selfs pcm are garbage to begin with, and there just that, a generic tune. and if it is a good tune, your gonna need to go back and retune when you get more mods which means spending more money on tuning. mine as well just get a tunner to begain with.
    ive got intake and headers waiting to go on. my next mods are problew gonna be rockers and some porting. the pulley is gonna be the last thing im gonna put on and im gonna have a tunner BEFORE the pulley goes on. to me the pulley should be the last thing you wanna change out.
    build more up on your car before you go switching pulleys
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  16. #16 Re: could i run a 3.4 pulley with these mods?
    just find a friend that will tune it. easier and you dont have to learn. done!
  17. #17 Re: could i run a 3.4 pulley with these mods?
    g.a.
    true..
    its slow.
  18. #18 Re: could i run a 3.4 pulley with these mods?
    im planning on a good tuning session with a buddy of mine to get all the quirks out of my setup. i can tweak later on with my afc and happy knob.
  19. #19 Re: could i run a 3.4 pulley with these mods?
    Aug 2008
    yea I probably wont do the 3.4... but do you think it is necessary with the mods i have after i do the colder plugs and the thermostat (and maybe the powerlog) to drop to a 3.5 to keep the boost up at stock range? I actually understand now what the real purpose of dropping pulleys is. I didnt know you actually lose boost when you do mods to help flow
  20. #20 Re: could i run a 3.4 pulley with these mods?
    Banned
    oswego
    yep you make the engine move the air so much more efficient now the blower has to spin even faster to keep up the same amount of boost as stock. The mods you have now might be able to support a 3.5 but you gotta scan your car first. Look for lean conditions and of course knock aka kr. lean conditions are o2's running lower than 920, and any knock is bad. The best way to scan like mentioned before on the first page is putting your car under the highest load you possibly can and gun it. 3rd gear pulls are going to be your highest load on flat surfaces, and if you can run uphill in 2nd if it's steep enough it'll work. When you do the third gear pulls let off the throttle before it shifts into 4th. Its the weakest gear in the trans and you will destroy it if you are at wot while in the gear.
  1. mods for the gxp
    By miller in forum 5.3L V8 (LS4)
    Last Post: 01-13-2010, 01:34 AM
  2. supporting mods for a 3.4 s/c pulley
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:12 PM
  3. Mods to Help MPG
    By anks106 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2008, 08:14 PM
  4. 3.5 Pulley WITH supporting mods
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 11:41 AM
