Thread: Lucas or STP in supercharger to stop knocking
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: Lucas or STP in supercharger to stop knocking
    SE Level Member McCoyH's Avatar
    Mar 2012
    Iowa
    It is still there when i accelerate, gets faster... no, stock pulley...
    ill check the a/c thing real fast
    Indianola Tint and Detail
  2. #22 Re: Lucas or STP in supercharger to stop knocking
    Mar 2012
    Iowa
    Noise is still there with ac on.
  3. #23 Re: Lucas or STP in supercharger to stop knocking
    I live here. TLSheff's Avatar
    I'm telling you... did this already myself ... Its main engine.
    Either valvetrain noise (broken lifter, spring, etc...)
    or its a chipped piston (doesn't usually happen on a stock pulley, but it could be possible)
    or like me, main bearing is gone, going, or something else lower end.
    Put the belts back on, put car on ramps, chock the wheels &/or set the parking-brake, leave it running and get under it, if its louder under it and it is above it guess what???
    If both belts are off and the noise is there, it can NOT be anything but engine, no belt to move anything else so write those off. Unless you have electric parts installed and your being sneaksie.
  4. #24 Re: Lucas or STP in supercharger to stop knocking
    A thought, is the CEL on? If so get it scanned, write the codes down, post them here and we can go further.
  5. #25 Re: Lucas or STP in supercharger to stop knocking
    Mar 2012
    Iowa
    Yeah. I opened up oil fill neck and it seems as tho the noise comes from inaide the valve cover... there arent any check engine lights on... i might do a motor flush and change oil with lucas and see if maybr one of the springs or somethibg is just not getting oiled...
  6. #26 Re: Lucas or STP in supercharger to stop knocking
    St. Louis
    Springs wouldn't tick unless broken. A collapsed lifter would tick as well. May be time to pull the valve cover and have a look.
  7. #27 Re: Lucas or STP in supercharger to stop knocking
    One other thing to check is the harmonic balancer they can over time wear out and make noises like that. Another possibility is flex plate but the noise ususally goes away when throttle is applied.
  8. #28 Re: Lucas or STP in supercharger to stop knocking
    Maybe it's time to yank the top friggen top end apart...and aren't you trying to sell this thing?
    I feel sorry for the poor sap that buys it with no knowledge of anything wrong...but I'm sure even a non-carpersonmanwomanguy would be able to tell something is up there. That ain't exactly, un-noticeable.
    Don't waste your money on a "Motor Flush"...
    Go get a big screwdriver and try to pin point the noise with it...hold it up to your ear to listen while it runs.
  9. #29 Re: Lucas or STP in supercharger to stop knocking
    michigan
    Try putting seafoam into the oil....mine did this and i think it was a sticky lifter. Put seafoam in and within 5 mins gone! Never heard it again...that was about a year ago.
  10. #30 Re: Lucas or STP in supercharger to stop knocking
    Mar 2012
    Iowa
    I put cd2 in the oil already.. didnt help... ive been using the mechanics stethascope type tool.. i guess tomorrow ill just take the valve cover off and have a look... and yes im selling it but not if its having motor problems.. im not a jack ass
  11. #31 Re: Lucas or STP in supercharger to stop knocking
    SE Level Member luvmykalashnikov's Avatar
    May 2012
    Nevada desert
    Don't use Lucas, it is just a thickener. It has no additives that help protect the engine and will dilute the additives in the oil. If you want thicker oil, buy a heavier weight oil.
    98 GTP coupe
    3.4 mps,plog,3"dp no cat,1.9 rockers 4" intake,EGR delete,Drilled 180,AL104,TBS removed,Glasspack,Overkill pcm,18",ect... At 5500' elevation
  12. #32 Re: Lucas or STP in supercharger to stop knocking
    Grand Rapids, MI
    I wouldn't dismiss the idea of the balancer...that's very plausible.
  13. #33 Re: Lucas or STP in supercharger to stop knocking
    Mar 2012
    Iowa
    Hmm... Well, knocking wasnt there this morning and hasnt been there all day... maybe the cd2 cleared it up? If it comes back I keep you guys updated... and in that case I'll prolly just start by taking the valve covers off and lookin at some stuff.
  14. #34 Re: Lucas or STP in supercharger to stop knocking
    St. Louis
    Wondering if this was a sticky lifter then???
  15. #35 Re: Lucas or STP in supercharger to stop knocking
    michigan
    Probably!
  16. #36 Re: Lucas or STP in supercharger to stop knocking
    Aug 2012
    Valley of the Sun, AZ
    I had a knocking/rattle sound at idle and went away with any rise in rpm......thought it was the coupler, replaced that and no change. Took both belts off and still rattled......replaced the harmonic balancer and no more noise. Just fyi if your still trying to fix, or for anyone else who is the same boat on here
    Ohio
    Uhh broke up flex plate dude.. Get under the car and look through the inspection plate.. And try to move it with a screwdriver
  18. #38 Re: Lucas or STP in supercharger to stop knocking
    Grand Rapids, MI
    Lol that was my thought as well, been there done that.
    But dude did say "no more noise." So he musta fixed it.
  19. #39 Re: Lucas or STP in supercharger to stop knocking
    Did you guys not see this thread is over 3 months old? Im sure he either fixed the problem or sold the car by now.
  1. Lucas 42.5 injector help
    By Dthreap in forum PCM Tuning
    Last Post: 02-15-2012, 02:34 PM
  2. What do i need to do to stop knocking?
    By Redbirds2230 in forum General Tech Discussion
    Last Post: 02-27-2011, 04:30 AM
  3. 04 GTP....Supercharger Knocking?? Why?
    By hazards280 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 12:29 AM
  4. Lucas Oil Stabilizer
    By millfire517 in forum General Tech Discussion
    Last Post: 02-10-2009, 10:14 PM
  5. lucas transimission fix
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-05-2008, 11:11 PM
