Thread: HELP...modified LIM for GenV S/C upgrade
Results 1 to 15 of 15
  1. #1 HELP...modified LIM for GenV S/C upgrade
    May 2012
    Santa Cruz, Ca
    So I bought this 98 GTP with a bunch of mods. One of which is the late model S/C on a 1998. I am replacing the blown engine, #5 cyl has a dime size hole on the edge of it. I pulled the super charger and the Monkey's I bought it from had removed a whole lot more of the intake than I imagined would even be close to correct. From the pictures I have seen here, all that has to be removed is about 7/8 inch to open the manifold to match the S/C outlet. These guys carved it up like a Thanksgivig Turkey!! The large hole on the throttle body end of the intake is where they stopped. The whole manifold is chopped out!! Hopefully I can post a pic. Any advice is helpfull. I am going to gasket match a stock 98 LIM to the 2004 S/C gasket and thats it. Am I correct on this?
  2. #2 Re: HELP...modified LIM for GenV S/C upgrade
    I live here. TLSheff's Avatar
    Is it opened up like this???
    Normally most don't open it up that big, this is more for a GenV intercooled setup. Post some pictures and we can tell you if it is a hackjob or worth while.
    (Photo submission stolen from BillBoost37 )
  3. #3 Re: HELP...modified LIM for GenV S/C upgrade
    Jan 2009
    Tallahassee, FL
    They may have opened it up for an intercooler in the future while they were in there, people go to the BBV hole then stop.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: HELP...modified LIM for GenV S/C upgrade
    May 2012
    Santa Cruz, Ca
    Looks just like that but they even went to the other side of the BBV hole. How do I post pics?
  5. #5 Re: HELP...modified LIM for GenV S/C upgrade
    best way, go to Image hosting, free photo sharing & video sharing at Photobucket. Create an account, its free, tons of space.
    Upload the pics from the computer, organize how you want.
    They have a direct copy link to each, copy paste with the little "Insert Image" button on the toolbar when you make a post.
  6. #6 Re: HELP...modified LIM for GenV S/C upgrade
    May 2012
    Santa Cruz, Ca
    ok here is the manifold
  7. #7 Re: HELP...modified LIM for GenV S/C upgrade
    May 2012
    Santa Cruz, Ca
  8. #8 Re: HELP...modified LIM for GenV S/C upgrade
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Quote Originally Posted by MUDWOMPER View Post
    Well the cuting for a straight line does suck but i was picturing something much worse but it isnt that bad. here is mine.
    i am guessing they tried to gasket match it how i did.
  9. #9 Re: HELP...modified LIM for GenV S/C upgrade
    Minnesota
    Thats how the one that came with my gen v looks. I was wondering if its a problem cutting it up that far. Any ill effects from that?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  10. #10 Re: HELP...modified LIM for GenV S/C upgrade
    Buena Park Ca
    Quote Originally Posted by Ricky21 View Post
    No problem at all. I mean it has it's advantages mainly the purpose of it is to even out the air flow to all cylinders and it helps if you smooth out the bottom how I did as well as the ports on the lim for a much smoother flow.
  11. #11 Re: HELP...modified LIM for GenV S/C upgrade
    Minnesota
    Gotcha thanks man
  12. #12 Re: HELP...modified LIM for GenV S/C upgrade
    I can even see the green of the Garleak gasket still on it.
  13. #13 Re: HELP...modified LIM for GenV S/C upgrade
    Jan 2012
    Philadelphia
    Quote Originally Posted by GTP89 View Post
    i thought you were suppose to machine it in like a square how the 04+ gasket goes why did you make it round on there
  14. #14 Re: HELP...modified LIM for GenV S/C upgrade
    It really depends on the intercooler. My intercooler stuck down into the lim. Which is why it was the shape it ended up.
  15. #15 Re: HELP...modified LIM for GenV S/C upgrade
    Buena Park Ca
    Quote Originally Posted by gtpeddie View Post
    Well I ported this one to gasket match a gen 3 not a Gen v. If I can I will port it to gasket match a gen v but idk how they look just yet.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. Need pcv help for IC'd GenV swap
    By 00gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 04:44 PM
