Thread: Why new motor mounts?
Results 1 to 16 of 16
  1. #1 Why new motor mounts?
    May 2012
    Huntsville, Al
    Guys, I see lots of people on the W-bodys change the lower engine and trans mounts. My Monte Carlo has 85K on it. The trans shop that is trying to help find a bounce out of the car says the mounts "look" great. Other than just the fluid showing a mess and maybe the mount squished out why are you guys changing them?
    My car has new axles with less than 300 miles, new wheel bearings less than 5K miles and new tires less than 3K miles that were road force balanced. The issue comes and goes but is a lot worse lately. I saw one post on here the lower mounts were neednig to be changed on his at 61K miles.
    I know mounts are cheap but have you guys seen a difference in the ride of the car when the mounts have been changed? Does changign to the rubber instead of the fluid filled show any improvement?
    Thanks for any help.
  2. #2 Re: Why new motor mounts?
    We change them when they are clunking, leaking and generally fubared.
    Here's an example of one that needs to be changed
  3. #3 Re: Why new motor mounts?
    May 2012
    Huntsville, Al
    Mine only clunks some times and generally looks very clean under the car. Maybe that isn't it.
  4. #4 Re: Why new motor mounts?
    Maybe.. The motor mount in the bucket is often soaked in oil etc and over time that degrades it and presto...it fails like ZZP.
  5. #5 Re: Why new motor mounts?
    If your mount is squished...
    Or if there is a obvious sign of fluid that has puked from it...
    Then yes, they need replaced...or another tall tale sign is looking at your motor from the top of the engine bay...does it look like its leaning to one side? One side...say, the left side lower than the right?
    Mounts are a great way to improve driveability and better traction/power transfer/feedback to the driver...I'd opt for the solid rubber replacements, and ditch thinking about putting some factory fluid filled ones back in...because...they will do just what the ones you have in there now are doing...FAIL.
    To add, click the link in my signature...there is a free mod called the "Dog Bone Flip"...look into it...that'll help as well when you put the new lower mounts in to take some strain off of them and increase the life of them by quite a bit.
  6. #6 Re: Why new motor mounts?
    May 2012
    Huntsville, Al
    The trans shop that has been looking over a slow body oscillation/vibration claimed the mounts looked great. I was just asking if the fuild had leaked and the car got cleaned before I bought it what would I feel if they had leaked. The bottom of this car looks almost new it is that clean with 85K miles now..
    They are putting in solid rubber moutns in the morning. I will flip the upper dog bone mounts tomorrow when I get the car home. This is a stock 04 Monte Carlo SS SC car that has been to the track a couple times.
  7. #7 Re: Why new motor mounts?
    GT Level Member Toms04compg's Avatar
    Michigan
    Dang bill my mount almost looks like that lol smh.
  8. #8 Re: Why new motor mounts?
    Tom...that was the purple hood liner car.
  9. #9 Re: Why new motor mounts?
    SE Level Member SLICK98's Avatar
    Jul 2010
    erie,pa
    My gtp has had a come and go vibration ever since i got it, i have only put about 3000 miles on it. I just put centric premium rotors on and bam noooooo vibration at all its like new. Just a thought.
    1998 GP Daytona Supercharged
    1989 GP SE Daily driver
  10. #10 Re: Why new motor mounts?
    May 2012
    Huntsville, Al
    Quote Originally Posted by SLICK98 View Post
    Even while you foot is off the brakes? Mine is not so much a vibration as a bounce. We have another car that I bought that was still for four years. My Monte Carlo has almost the same frequency of oscillation as the car with 4 year flat spotted tires.
    Just wondering if the bounce in the seat is from the motor moving around too much. Will know more tonight I guess.
    Last edited by W30post; 05-11-2012 at 07:38 AM. Reason: Adding more info on the thing I am chasing
  11. #11 Re: Why new motor mounts?
    May 2012
    Huntsville, Al
    OK, motor mounts changed to solid rubber mounts. I flipped the radiator support mounts also. I can tell a difference in the vehicle dynamics but the original problem I am chasing is still there.
    Now what next? Is it the 25 lbs of road force bouncing the car around?
  12. #12 Re: Why new motor mounts?
    I live here. TLSheff's Avatar
    Next I would look into this, just as an option of where to start. Clunks can be all sorts of things, I have to inspect my car for one it started about a month ago... tech said it could me a mount (motor/tranny or front strut) or it could be the intermediate shaft. but start with the easy one.
    Red circle... does yours look worn like this???
    http://www.grandprixforums.net/what-...pic-62788.html
  13. #13 Re: Why new motor mounts?
    May 2012
    Huntsville, Al
    I will have to look today but I have not noticed anything like this. I do have the intermediate shaft clunk sometimes but I know what that feels like and how to reduce it for a while..
  14. #14 Re: Why new motor mounts?
    Sep 2011
    Canada
    This is a very helpful thread for me! I also have the bounce/clunk. I can see my engine leaning more to one side. Is the motor mount hard to change? I'll be checking my struts tomorrow too!
  15. #15 Re: Why new motor mounts?
    May 2012
    Huntsville, Al
    Quote Originally Posted by mrfreez View Post
    Sorry, I don't know how hard it was. I paid a shop to install the lower mounts. I didn't have the time to mess with this.
  16. #16 Re: Why new motor mounts?
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Not only are bad mounts a result of lots of noises but they change your drivetrain geometry which results in vibration under acceleration. Plus one bad mount puts undo stress on all of the other mounts, accelerating their failure and eventually resulting in more necessary repairs. They're so cheap and easy to replace that it's a good idea to get them swapped out of they're bad.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  1. Motor Mounts
    By Classy Pontiac in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2012, 03:25 PM
  2. Motor mounts
    By Chizzler in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2010, 08:13 PM
  3. Motor Mounts
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 02:43 PM
  4. top motor mounts
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 12:49 PM
  5. motor mounts
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-01-2009, 01:35 PM
