Thread: Bad hesitation under acceleration
Results 1 to 4 of 4
  1. #1 Bad hesitation under acceleration
    SE Level Member 3R1CD4V15's Avatar
    May 2011
    Virginia
    1997 gtp
    stock
    156k miles
    This problem has gotten way worse now. I used to just have a pop sound under load, but now it is bad hesitation if i go above 2500 rpms.
    The rpms will drop down about 200 then come back up until i let off the gas.
    I have sel codes p0420 and p0300.
    I replaced cat and fuel filter, disconected the battery(does that reset codes?). And still have the same codes...
    I would say it has gotten worse since i have done these things.
    The old cat didnt look bad. replaced with a zzp high flow
    the old fuel filter was bad tho, I could barely blow thru it...
    I took one plug out to look at it and it looked brand new. (a little black on the white part)
    The wires look brand new also.
    Ive had this car a little over a year and the plugs and wires look like they are maybe 2 years old?
    I think I am gonna pull all the plugs to look at them to see if this could be a simple fix.
    Then maybe rent a fuel pressure tester.
    Any help would be much appretiated.
    Thanks,,
    Eric
  2. #2 Re: Bad hesitation under acceleration
    Replace all spark plugs.
  3. #3 Re: Bad hesitation under acceleration
    May 2011
    Virginia
    Replaced Plugs and wires.
    All codes are now gone.
    Car is fixed.
  4. #4 Re: Bad hesitation under acceleration
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Yeah most problems like this are going to be ignition related. The wires can look perfect too and still be completely F'd. It's cheap insurance to replace that stuff.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  1. 01 GTP Hesitation
    By chefchicago in forum General Tech Discussion
    Last Post: 03-21-2012, 09:06 PM
  2. hesitation under acceleration
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 03:16 PM
  3. Hesitation
    By polo3433 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-15-2010, 02:09 PM
  4. Motor mounts and hesitation rough acceleration
    By Jerime in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:40 AM
  5. 1990 GP 3.1 Hesitation and dies under acceleration
    By jtmon in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-09-2010, 04:59 PM
