Thread: HELP flashing check engine light/ poor acceleration
Results 1 to 19 of 19
  1. #1 HELP flashing check engine light/ poor acceleration
    gardner,mass
    I was just driving down the road after getting a car wash and all of a sudden my 2000 gtps idle changed and it sounded like it was running on less pistons and the service engine light started blinking. My Acceleration is poor but i can still get it up to speed. Im thinking skipped timing or plugs or something idk please any input would be great this is my daily driver and i need to get to work tomarrow.
    Dec 2010
    DMV
    Flashing light means misfire.
    Have you had the service light scanned yet?
  3. #3 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    btw i just changed my plugs and wires about a month or two ago also changed fuel filter and fuel pump a few weeks ago
  4. #4 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    it just happened and nowhere is open to scan it
  5. #5 Re: HELP flashing check engine light/ poor acceleration
    Jul 2010
    Do you know anyone with a scanner by chance?
    Dec 2010
    DMV
    Well the scan would help tremendously.
    Otherwise you can check to see if any wires are melted, check all wire connections and also check your coil packs for corrosion.
  7. #7 Re: HELP flashing check engine light/ poor acceleration
    What plugs are you running?
  8. #8 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    al 606s gapped at .055
  9. #9 Re: HELP flashing check engine light/ poor acceleration
    Hook it up to scanner and see what cylinders are causing the problem.
    Then check wires and coils and maybe swap them around and see whats up.
  10. #10 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    ok well can this be caused by anything major like intake manifold gasket or something huge that will cost me a fortune
    Dec 2010
    DMV
    Quote Originally Posted by ginseng View Post
    Seems unlikely but you never know until
    It's scanned and you check the codes. I wouldnt worry about it too much. Rest easy, check it in the am and go from
    There.
  12. #12 Re: HELP flashing check engine light/ poor acceleration
    Right..let's skip all the easy things and go right for new engine. Since you're the one footing the bill...it sounds good.
    Technically, it means "Catalyst damanging condition" Which..is usually caused by a misfire.
  13. #13 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    well i know my cat was going i could hear it while driving real shaky is it a possiblity its just clogged, i pulled all the wires off the coils and they all spark and the misfire im getting is 305
  14. #14 Re: HELP flashing check engine light/ poor acceleration
    You didn't feel it was relevant to share that information to begin with? Seems like the problem with this car exists between the seat and the steering wheel.
    Fix the known issues and then see what you have left.
    Some people's kids
  15. #15 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    hey bill no need to be rude ive put 1500 worth of parts in the car in the last 3 months, and ya the cat was next on my list just ran out of money. Im not coming here for a lecture im coming here for probable answers on what could cause a misfire and im surprised usually you give the best answers bill and i was hoping you would come into this post and help me out but know youve shown me a different side of you, changed my mind. Anyway no drama i just was technical answers thanks
  16. #16 Re: HELP flashing check engine light/ poor acceleration
    you cant expect good help off the internet with out giving full details of what has been done already.
    a list of whats been done helps a lot. holding on to 1/2 the info wont help any one help you.
    and i'd feel safe to say when all info is given, bills one of the best net diagnosis around.
    now carry on fellas
  17. #17 Re: HELP flashing check engine light/ poor acceleration
    St. Louis
    Well, since P0305 is a code for misfire on Cyl #5, start there. Check the wires for obvious damage. Since this happened after getting a car wash, is it possible that you got some water somewhere it shouldn't have? If the wire looks good then try swapping it with a good wire and see if the miss follows.
  18. #18 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    ok well lets see what been done
    Sway bar
    Struts
    rotors
    breaks
    plugs (al 606s
    wires
    all fluids (inc sc oil)
    thermostat 195
    Tires/ alignment
    Fuel filter
    fuel pump
    headlights
    oil pan
    break lines
    exaust welded (small leak)
    Gas line
    Throttle body gasket (cleaned tb)
    Egr hose/ egr valve
    CAI
    Think thats all i can think of atm
  19. #19 Re: HELP flashing check engine light/ poor acceleration
    gardner,mass
    ok well i guess my next question should be, im going to replace the cat i see one on zz performance for 79 what is the stock size i need and can these things clamp on or do i need it welded
    ZZPerformance - Catalytic Converters #ZZ-CATC
  1. Flashing check engine light (beginner)
    By xander37 in forum General Tech Discussion
    Last Post: 11-28-2013, 11:24 AM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. Engine light flashing never seen that before?
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 02:14 PM
  4. Flashing check engine light!!
    By JOGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2010, 08:55 AM
  5. check engine light flashing help
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:09 PM
