Well, since P0305 is a code for misfire on Cyl #5, start there. Check the wires for obvious damage. Since this happened after getting a car wash, is it possible that you got some water somewhere it shouldn't have? If the wire looks good then try swapping it with a good wire and see if the miss follows.
